'64 Champ - dim headlights on one side?
  • Electrical: '64 Champ - dim headlights on one side?
    Bought two new sealed beam headlights for my '64 Studebaker Champ P/U. Passenger side bright and clear. Driver side pale and dim. Switched them. Same problem, so it's not the light units. Any ideas out there?
    Looks like you left some information out of your thread title that might attract folks with an answer to your problem.
    And you might want to put it in the Technical Forum rather than general discussion.
    '33 Rockne 10,
    '51 Commander Starlight,
    '56 Sky Hawk
      Bad ground on the dim side. Run a bare wire from the headlamp pod to one of the screws holding it to the fender.
        The Ground wire from the Seal Beam Plug to the Headlight Bucket is frayed, broken or disconnected, or Bucket to Fender has poor or no ground continuity.
        A good descriptive TITLE is a must, for help and search history, a Joke does not help.
          I agree. When I rewired my pickup one of the lights was dim even though I thought I had good grounds. I ran a dedicated wire to each bucket and the lights are fine.
            The solution might be as simple as running a self-tapping screw through the headlight bucket to the fender, producing a clean fresh ground.
            '33 Rockne 10,
            '56 Sky Hawk
              Yep. Should have checked the thread title. Sure wasn't what I thought I typed. Anyway, most responses were correct--bad ground on driver side bucket.
              - - - Updated - - -
