I have a '50 Champion Starlight. The vent windows are so loose and swing so easy that they will not stay in the full open position. As a result, personal comfort is negatively affected on a hot day. The hinges appear to be held together with rivets. Has anyone successfully remedied this problem before?
Vent Windows too loose, '50 Champion
Either that, or the shaft is broken and the spring is in the bottom of the door.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
60V-L6 - 60 Lark convertible
It's been a while since I had the trim panel off my door but, isn't there a hole in the door shell to access that adjusting nut so the vent needn't be removed to tighten it?"All attempts to 'rise above the issue' are simply an excuse to avoid it profitably." --Dick Gregory
'33 Rockne 10,
'51 Commander Starlight,
'56 Sky Hawk
You'll have to remove the inner window moulding that the wind wing and rubber are attached to. Not difficult. On my 52 there is a hole to get an oil can spout in to lubricate the pivot, but that's it. There's a pic in the Body section of the shop manual.3H-C5 "The Blue Goose"
If you tighten that nut do it with some care. They tended to rust up. Lube it good with something that dissolves the rust. If you break it you will have to replace itMilt
1961 Hawk 4-speed
1967 Avanti
1961 Lark 2 door
1988 Avanti Convertible
Member of SDC since 1973
