Angle & vibrations...
  • #46
    I removed a driveshaft from a 1964 Commander to replace the "U" joints and had bad vibration afterwards. I took the "U joint loose again and I rotated the shaft 180 degrees and installed the "U" joint again and the vibration was gone.
    • #47
      Wow, the US prices sure are lower BIGtime! Still; I'm gonna visit my fav workshop-&-also-speedshop tomorrow to see what they say...
      About turning the shaft half-a-turn with the joint still in the shaft; since I've had it appart now I don't remember how it was fitted before but I might be lucky, sure hope so!
      (Today was a day when I didn't even go near Josephine, had to support Sonja's windowframe-instal & move + extend the puppies own yard. No picture of the yard-work thou.
      Now it's only the rest do be done... there's nothing behind the planks, just air so we're adding some stuff while we're at it & the lowest part from the top of the windows (that's gona be replaced too) are gona have different planking & become white to flow with the buildings on eash side, kinda like this:
Name:	Nya Laduvæggen.jpg
      Enough off topic for today!
      Josephine
      -55
      Champion V8
      4d sedan
      • #48
        Nothing new so far here & I'm not gonna go on more about the barn wall work, it's way worse than I thought... (Just imagen a brick wall on top of a wooden plank laying flat on earth & then on top of this 1 meter high brick wall another wooden plank, also rotten, & another brick wall on top of that!) & the puppies are growing, funny how different they are in way of behaving, such personalities!
        Anyway, barnwork & dogs have kept me away from Josephine bigtime, but a thought hit me yesterday: I'm gonna contact a pal over in the US to buy & send me shims, otherwise this is gonna go on forever.
        Josephine
        -55
        Champion V8
        4d sedan
        • #49
          Been in contact with my US (originaly Canadian) friend & he's at it but it takes ages, busy as he is. Connected the rev-counter instead & got me a Hurst shifter:
          (Not installed yet, just feeling it!)
          Josephine
          -55
          Champion V8
          4d sedan
          • #50
            Oh, allmost forgot the off-topic's:
            (The bricks on top by the door are replaced now & there's balks above the window openings, & meet Carmenzita, the gal we kept!)
            Josephine
            -55
            Champion V8
            4d sedan
            • #51
              On Topic:
              First I thought I'd go for the ones that Junior sugested but later on I found I wanted the ones with hole instead of a slot, it feel like the slot would / could / might glide out... So I went for Sweet Old Bob's Summit sugestion instead, this one:
              Josephine
              -55
              Champion V8
              4d sedan
              • #52
                Originally posted by Noxnabaker View Post
                On Topic:
                Nox...I wondered if the slotted ones would walk-out too so I put some witness marks on the spring pads and springs and they have not moved at all in 8 years they have been in there...manual transmission and more than a few spirited clutch-drop starts and they're all good. cheers, junior
                1954 C5 Hamilton car.
                • #53
                  Okidoki, good to know! But now my pal has already orderd the ones with holes.
                  (Off topic: doing the shifter linkage now, easy with just one rod + already a small platform with a hole in on side of the gearbox (see arrow),
                  only recuired one more drilled hole, but mighty tight under there because I put the silencers as far forward as possible to avoid resonance that always apears on sb MoPars around 45-50 m/h.)
                  Josephine
                  -55
                  Champion V8
                  4d sedan
                  • #54
                    A week ago Sonja's Subaru had to go to the Subaru doctor (some stuff is way to horrible for me to work on as it's a modern car) & I had to lower Josephine from her stands & get Ozzian from school... I have taken down most of the exhaust system so the pipes ended before the rear axel & WOW!!! that is LOUD inside!
                    Anyway; the pinion angle is still the same & the vibrations are still there / here.
                    (By now I've also fetched him 2 times from school & gonna drive him there tomorrow, he hates it...)
                    So: the vibrations are still there & shims are welcome.
                    Josephine
                    -55
                    Champion V8
                    4d sedan
