I have the wheels off the ground and have disconnected the linkage at the transmission. With me and and the car is super safe mode, I am able to get N, 2, 1 and R but can't get P (park). At one point I was in park as I tried to rotate the rear tires and they would not move. Other than that one incident I have not been able to find park. Anybody have an idea why no park? Thanks, Chet
No Park on 3 Speed Automatic Transmission '58 and Later
Tags: None
My first guess would be a broken park pawl."All attempts to 'rise above the issue' are simply an excuse to avoid it profitably." --Dick Gregory
'33 Rockne 10,
'51 Commander Starlight,
'56 Sky Hawk
Don't panic yet. You may need a little more leverage than you're giving it. Don't break it, though. But try a bit more oomph before you give up.
Its unlikely that you were able to find park at one point while the car was up in the air, then broke the parking pawl while it was not in use and off the ground.
Another possibility is the linkage is somehow out of whack when the car got put up on jacks. Did the linkage bind up in any way while jacking the car? Did you lift it corner by corner? Some serious flexing can occur on some, depending on where you jacked the car.
Or disconnect the linkage at the trans and try to get it into park manually.
Unless I'm missing something in the sequence of events.
Or did you accidentally put it into P for passing gear while speeding around that slow poke Hellcat?sals54
Our '52 Commander still has no working park in the trans and I have not dealt with it yet, just trying not to park on unlevel ground and using the parking brakes. I can attest to the flexing as I have discovered that if the Commander is jacked up by any point except center front or center rear the doors won't open. And the body and frame are solid, not weak from rust either.thom
I hope someone can answer Mrs K Corbin's comment favorably. I sure hate having to pull the tranny and tear it apart...an expensive undertaking to say the least. In reading the comments I gather it is okay to drive the car and not tear up the transmission...yes/no!
Remove the throttle pressure rod at the pin that holds it. Now remove or adjust the shift rod so it gets all of the gears, then put the throttle pressure rod back on AND adjust it so it is not 'pulling hard. It should just hook up without too much pull on the lever. You are almost there! .
If there is too much 'pull' on the throttle pressure rod , it keeps the trans from going into 'park'
'33 Rockne 10,
'56 Sky Hawk
S WOW!! I followed your take on how to find Park and it worked. I do have P after all. I am not sure the transmission starting off in 2nd is shifting to the next higher speed which I understand is adjustments to both throttle control and throttle release rods. It is nice feeling to not have to pull the transmission. Many thanks to all who offered their thoughts. Chet
Originally posted by thom View PostOur '52 Commander still has no working park in the trans and I have not dealt with it yet, just trying not to park on unlevel ground and using the parking brakes. I can attest to the flexing as I have discovered that if the Commander is jacked up by any point except center front or center rear the doors won't open. And the body and frame are solid, not weak from rust either.Gary L.
This may indeed be my problem, as my throttle pressure rod where it attaches to the bellcrank is a home-made affair.
I'll have to look into this when I get the time.
Originally posted by (S) View PostRemove the throttle pressure rod at the pin that holds it. Now remove or adjust the shift rod so it gets all of the gears, then put the throttle pressure rod back on AND adjust it so it is not 'pulling hard. It should just hook up without too much pull on the lever. You are almost there! .
