Hooking Up Defroster Only
  • Cool/Heat: Hooking Up Defroster Only
    I want to hook up my defroster only, not the heater. Is there a reducer which will let me join the hoses from the water pump to the smaller hoses which go to the defroster?...
    Auto parts stores have all sorts of hose adapters. If you can find a good one, they should have what you need.
      Don't forget the local hardware and big box stores. Ace and Menard's locally carry a ton of brass and iron fittings. Home Depot has some selection but not as good as the other's and usually higher prices.
      Bob
        Any copper pipe/tube reducer from the plumbing supply at your local ACE hardware would work. Much cheaper than brass.
        '33 Rockne 10,
        '51 Commander Starlight,
        '56 Sky Hawk
          Don't expect a lot from the defroster. It's design is not like the ones in modern cars.
          60V-L6 - 60 Lark convertible
            I take it that the DEFROSTER Switch is 2 speed? And thank you ALL for the help...
              That's true. Much of the defroster's heat is derived from the cabin heat that is circulated back through the defroster.
              And yes; the defroster fan should operate on two speeds.
              '33 Rockne 10,
              '56 Sky Hawk
                This is how I did it, house copper water-piping
                & shorter hoses:
                (Josephine also can run on LPG, that's why the round stuff in the corner, that has to be heated, & no; it's no Studebaker engine.)
                Josephine
                -55
                Champion V8
                4d sedan
                  Looks like a Mopar? -Jim
                    SI shows one in their catalog #198653, 59 - 62 @ $24.00 it is 1/2" through with a 3/8" "T". My54 also has the same "T". The heater gets its energy from a water heated coil. I can remember in the day with a frosted windshield and looking through a 6" hole most of the way to work, thank goodness for modern defrosters. The air conditioning pump is an integral part of modern defrosters, the system dries the air before it reaches the cold windshield. Unfortunately that system was not available with Studebakers, the best you could get was moist hot air. One Ford car I had was equipped with fusible link in the water control valve if the system became over heated with super hot steam the valve would close to avoid any injury.
                      To replace the rusted out stock "T" fitting in the heater hose that goes up to the defroster, I bought brass "T" fittings that fit the 5/8" heater hose with the "T" for the 3/8" defroster hose at Home Depot for under $3 each. They were for PEX plastic plumbing tubes. I'd bet they have a fitting that will simply splice the 5/8" heater hose to the 3/8" defroster hose too.
                        Yes Jim, it's a 318 MoPar, Studebaker V8's are few here & mostly in cars...
                        Inside I made my own box with fan from some strange heater from an old van:
                        Josephine
                        -55
                        Champion V8
                        4d sedan
