Rockne with a Dictator engine?
  • Engine: Rockne with a Dictator engine?
    Rockne with Dictator engine??
    Has anyone ever swapped a 1934 Dictator engine into a Rockne? From what Ive read its the same casting and should work, but I am checking to see if anyone has actually done it and knows of any issues?
    Thanks
    Alan
    I take it you need a Rockne engine?
    There’s a ‘32 model 75 here that needs a new home. Looks presentable but the body is pretty rough; would make an excellent parts car. Currently have the gas tank out being cleaned so it can be driven again.
      how rough is pretty rough?
      Mine is a 32 model 65 so the model 75 engine wouldnt fit. What type of car is the 75? coupe? sedan?
      Thanks
        It’s a sedan. It’s complete and doesn’t look too bad, but most of the wood needs replacing and a lot of the bodywork is patched up.
          Is this the same engine block as the later Commander six? Those are thick on the ground.
          60V-L6 - 60 Lark convertible
            Yes same block but the Commanders had modifications... different locations for fuel pump, water pump, clutch connect etc. I am trying to keep it looking the same
            ALan
              Has anyone ever swapped a 1934 Dictator engine into a Rockne? From what Ive read its the same casting and should work, ...
              I'm speculating with what little resources I have quickly available, and some one may correct me but, I believe the '34 Dictator had the 205.3 cid engine introduced in the Model '53' Studebaker in 1930, two years before the design of the Rockne Six. I believe the Rockne casting was first installed in the Dictator in 1936 with a 217.8 displacement.
              I am always available to be educated.
              '33 Rockne 10,
              '51 Commander Starlight,
              '56 Sky Hawk
