Location of hood brace on A/C GTs
  • Cool/Heat: Location of hood brace on A/C GTs
    Can someone with a GT that has original A/C installed post a picture of the condenser mounting and especially the hood brace? I believe my parts car was tampered with as additional holes were drilled above where the original holes are for the brace on the left and the clip on the right. Perhaps this was done to clear the condenser itself. What is CORRECT? Thanks for any help.
    Rob in PA.
    Here are some shots of my ‘63. Let me know if you need more.
ID:	1728629Click image for larger version
ID:	1728630Click image for larger version
ID:	1728631Click image for larger version
ID:	1728632Click image for larger version
ID:	1728633Click image for larger version
      Thank you ColoradoHawk. I do need to see the right side where the clip is for the hood support. Could you post a pic of the rod itself as I believe it is different from a non-A/C rod. I may need to buy or make one. My condenser mounts in the same position and hardware as yours does.
      Rob in PA.
        This 1954 GT has a factory AC. It originally belonged to a fellow that worked at ONAN Corporation.
ID:	1728663Click image for larger version
ID:	1728664Click image for larger version
ID:	1728665Click image for larger version
          Here are a few pix of the hood prop on the wife's 63GT which, AFAIK, has factory AC. Click image for larger version
ID:	1728668 Click image for larger version
            Thanks to all who posted pictures. very helpful in determining proper installation and location of correct equipment and hoses.
              Thanks to everyone who took the time to take and post pics. It appears that the factory drilled additional holes above the regular non-A/C holes and reinstalled the clip for the base of the hood support rod on the passenger side. They apparently added the clip with a bolt attaching it on the driver's side also above the original hole as the rivet was not used. My condenser is attached at the top with the bolt heads OUT with the lock and nut toward the radiator. I still am not sure what the rod should look like as there is a difference shown. I thought there would be a bend also where it clips in the down position.
              Rob in PA.
                64 Factory air
                I just wanted to show my 64 GT Hawk Factory air pics.
ID:	1728686 Click image for larger version
                It would seem that in the pics above, the hose routing wasn't well thought out with them running over the top of the belts. However with my rig, it's going to be a challenge to remove that lower hose from the compressor without a lot of other things first..
                64 GT Hawk (K7)
                1970 Avanti (R3)
                  The parts book shows 2 different prop rods with or without A/C. Depending on the condensor you may be able to use either one.
                  Claude Chmielewski
                  Studeski
                  http://www.studeski.com
                  Fillmore, Wisconsin
                  47 M-16 Truck
                  53 Commander Regal HT
                  53 2R5
                  60 Lark VIII Convertible
                  60 5E7 Champ pickup
                  62 5E7 Champ no box
                  62 GT Hawk 4 speed
                  63 Lark VI parts car
                  63 GT Hawk R2 4 speed
                  64 Commander Wagonaire
                  64 Daytona Convertible
                  50 Champion Regal (parts car)
                  36 Dictator
                  36 Dictator in pieces
                    Can someone please shoot a pic of the prop rod itself preferably in the horizontal position?
                    Thanks
                    Rob in PA.
                      I have a couple ... wait a sec or two...
                      64 GT Hawk (K7)
                      1970 Avanti (R3)
                        Here's a full frontal
                        64 GT Hawk (K7)
                        1970 Avanti (R3)
                          Thanks
                          Rob in PA.
                          See post #5 above.
                            Originally posted by JoeHall View Post
                            See post #5 above.
                            Why does your prop rod have a bend in it?
                            64 GT Hawk (K7)
                            1970 Avanti (R3)
                              I dunno. Also, the anchor/pivot end has an interesting double bend. It looks like a factory job (versus local fab), fits like a glove, everything clears nicely, and it deploys and stows easily. My other two Hawks have the crook at the top, about 6" long, where it attaches to the hood when raised. But neither of those cars came stock with AC, as the one in the pix above did.
                              If anyone has a body parts manual, it would be interesting to see if there are different part numbers for props on AC equipped cars.
