Alternator 3 wire hookup
  • #16
    Great up grade. I do the 3 wire 10si on every car I have after the gen or reg die (or sooner). Did it on the Lark with a warning light.
    • #17
      Originally posted by BrianInReno View Post
      4. What wire gauge would you recommend from the alternator to the + battery terminal? Is 10 gauge adequate?
      Thanks fpr the help.
      A #10 wire will work if you don't use a huge amp alternator, but it's marginal. I've done it several times on cars without any accessories and minimal load, but it's better to use at least a #8. I used #8 on my Hawk, even though I reduced the normal load by 65%. If you have a lot of load, and big amp alt. you might even want a #6.
      • #18
        Thanks everyone for your suggestions. Sounds like the 3-wire alternator is the way to go but will need to add the warning light. The mounting bracket mod is doable.
