I have been a Studebaker Driver’s Club member since about 1984, but I am new to the forum. I have a ’63 Super Hawk that I do not drive very often at all. The problem I am experiencing is that the fuel evaporates from the carburetor bowls and I must prime the carburetor manually, which as you can imagine is a PITA, especially since it’s supercharged.
Many years ago, I added a small electric pump to help resolve this issue, but this old electric pump does little if anything and I plan on removing it.
I recently ordered a Holley Blue electric pump, Billet By-Pass regulator, a delete plate/gasket, a ½” spacer (that will be placed between the top of the carburetor and the supercharger top cap) and a fuel pressure gauge. I plan to address the return fuel line that runs off of the fitting at the top of the original R/2 mechanical fuel pump with this Billet regulator: https://www.holley.com/products/fuel...s/parts/12-879. Although I would prefer a Mallory set-up, I believe that the Mallory kits are overkill for this application, not to mention that they are substantially more expensive.
I believe I have the “equalizer line” issue sorted, but I wanted to see if the members here agree with my plan: The 1:1 Boost Reference port (a feature of the Holley Billet By-Pass Regulator) has a brass fitting at the top of the regulator (which I linked to above) that I plan on running between the regulator and the 1/2" spacer (I will drill and tap a brass fitting into the spacer). This way, the vacuum line will be on top of the carburetor and between the top of the carb and the supercharger carb top cap. The 1:1 Boost Reference of the Holley regulator should properly address the Equalization Line issue. One of my concerns was the screened breather hole with internal flap that is on the top of the carburetor-supercharger top cap – that it might interfere with the vacuum of the 1:1 boost reference port feature of the Holley Billet regulator – but the Holley tech dept. told me that would not be an issue. The return fuel line at the bottom of the Holley regulator will be utilized for a return fuel line back to the tank and will properly address that issue. I plan on mounting this regulator by using a bracket at the location of the mechanical fuel pump delete plate for a neat and easily accessible installation.
So, what say you regarding my plan? Thanks in advance for any advice.
