The drivers side trunk lid hinge on my "new" '52 Commander has begun to give me grief. It worked fine for the first several weeks that I had the car, and the trunk was opened and closed quite a few times. Now when I close the trunk the lid shuts down as it should on the passenger side but stands off/up on the drivers side. If I push it down with my hand it still won't go down as far as it should. I have lubricated the hinges and nothing appears to be bent or have slipped. I suppose I will have to remove the trunk lid and "persuade" the hinge to go a little lower? Any suggestions or tips? Thanks.
trunk lid hinge problem
Tags: None
I wonder if one of the springs has broken or lost tension."All attempts to 'rise above the issue' are simply an excuse to avoid it profitably." --Dick Gregory
'33 Rockne 10,
'51 Commander Starlight,
'56 Sky Hawk
Did you lubricate the hinges when you bought the car, before opening and closing the trunk quite a few times?RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
60V-L6 - 60 Lark convertible
If the sprints are OK, the hinge itself probably bent. They are not really over-engineered, given the weight of the trunk lid.
I had this problem and ended up having to re-bend and then weld on a stiffening brace to the hinge itself. Not all that easy of a project but it helped quite a bit.
https://forum.studebakerdriversclub....runk-hinge-fix
