I have a 1951 2R11 which has developed electrical issues. I will be driving and all of a sudden the truck will stop running. I installed a new 6 volt battery last year replacing an 8 volt battery . Not knowing what adjustments were made to the old regulator I installed a new voltage regulator, polarized the generator and everything seemed ok, the amp meter was showing a slight positive charge. Turned the lights on and it went slightly negative as normal. Turned them off and the amp meter stayed slightly negative. Went out for another ride again about 10 miles and the truck stopped running. The battery was dead. Recharged the battery, started the truck and the amp meter pegged at a negative 3.5 amps. I was able to get it home. Turned the ignition off and the amp meter stayed -3.5. Started the truck the amp meter read slightly negative and that’s where I am.
Any thoughts as to where to start looking?
