Can't find stop light switch 57 President,. What's it look like?
  • WinM1895
    Last I looked, correct me if I'm wrong...Studebaker wasn't made by Ford. (except for that pesky 289)!!!! Last time I needed a Ford part for a 93 Cobra, it took them 2 weeks to get a speedometer gear.
    I can get a similar part from my Stude vendors on a couple of days.
    Some people may be interested in the fact that this Ford switch is the same as Studebaker, that's why I listed the part number, posted a pic of it.
    If it took two weeks for you to get a speedo gear, it was either on back order, or you ordered it from a source in Madagascar!
    Packard 352 wasn't made by Ford either.
  • bezhawk
  • WinM1895
    It's a pretty standard pressure switch used on all makes and models for years. Available at SI, as well as any local auto parts store.
    C1AZ-13480-A (replaced 0A-13480) .. Stop Lamp Switch (Motorcraft SW-24) / Available from Ford & auto parts stores.
    1940/66 myriad FoMoCo vehicles.
    Here's a pic of the little darlin' (13480) from the 1949/59 Ford Passenger Car Parts Catalog:
  • jnfweber
    Also lost in the edit was: "Thanks, guys!"
  • jnfweber
    However, my reply, "Found it" was deleted.
  • jnfweber
    Tried to edit my reply. Not possible using smartphone. Nor could I post a photo of the little switch.
  • Bud
    Your local NAPA or Carquest store should have a replacement switch in stock. The NAPA number is SL134 and the Standard Motor Parts number is SLS27. Be sure you have the special socket needed to do the switch replacement or a relatively easy job could become rather hard. Bud
  • tsenecal
    Here is one from speedway that is reasonable. They have a few different variations of connectors also. https://www.speedwaymotors.com/Speed...-NPT,1971.html
  • acolds
    Pic from manual
  • rockne10
    Originally posted by jnfweber View Post
    Is it available from S.I.?
  • Mike Sal
    Look a little further forward on the drivers side just below the inner fender skirt. The switch is screwed into a brass block which is bolted to the frame rail. There should be 2 wires heading down & plugged into the top of the switch.
  • Can't find stop light switch 57 President,. What's it look like?
    Title says it all. Jason told me it was located deep near engine side firewall on the left, below hydrovac booster. Should be the same for all sedans 55-58, and maybe earlier, but not coupes. Is it available from S.I.?
