Rich do you know of a source for the copper washers? S.I. doesn’t carry them.
sending unit
Rocket1.
The detailed solution to your problem ia at the SDC Website: --Resources, --Studebaker Tech Tips, Specs and Data, --Replacing the Cork Float on your Studebaker Fuel Level Sending Unit.
Replacing the Cork Float on your Studebaker Fuel Level Sending UnitHenry Votel,
Forest Lake, MN
Buying & Selling Studebaker Parts in MN & WI
For those who can't get a used or free neoprene float from a donor sender to replace a rotten cork float, Aircraft Spruce & Specialty Co. sells a replacement float, part number 05-03395, for $3.35. Shipping charges are extra. Modification of your current sending unit is not required as described in post #7 above. The hole down the center of the float is 0.165 inch diameter, so a larger outer diameter washer may be needed on the end of the wire to keep the float captive.
https://www.aircraftspruce.com/catal...t-05-03395.phpLast edited by Mark L; 06-22-2019, 08:56 PM.Mark L
Originally posted by Mark L View PostFor those who can't get a used or free neoprene float from a donor sender to replace a rotten cork float, Aircraft Spruce & Specialty Co. sells a replacement float, part number 05-03395, for $3.35. Shipping charges are extra. Modification of your current sending unit is not required as described in post #7 above. The hole down the center of the float is 0.165 inch diameter, so a larger outer diameter washer may be needed on the end of the wire to keep the float captive.
