Exact Hawk traction bar measurement needed (part 2)
  • Frame/Springs: Exact Hawk traction bar measurement needed (part 2)
    This photo shows an Avanti. I would like this same measurement from a Hawk with factory traction bars. (Center of leaf spring mounting bolt to center of traction bar mount stud.)
    The instructions with the repro frame brackets give a measurement from the axle shaft centerline to the center of the trac. bar mounting stud on a horizontal plane. The measurement in the photo would be much easier to get right. Thanks in advance!
    I have 9 1/8" center to center as shown.....my brackets are not factory...I am using the Fairborn (or T-Bow's) kit with the adjustable bars.
    You my want to wait for someone who has a factory installed set shines in before you set the torch afire.
    Bill Foy
    1000 Islands, Ontario
    1953 Starlight Coupe
      Also, remember the front spring mounting bolt on the other side (drivers side) is in a different location; the upper hole if it's correct.
        Matt, I'll get those measurements for both sides for you in a little while. Mine is original and on the ground for the correct angles. I just got home from the eye doc and my eyes are dilated, so give me a little time for them to settle down a bit. Bill
          OK Matt here's what I've got on mine. Both sides the spring is mounted in the lower hole of the spring perch bracket and I used my 1" wide steel rule (somewhat flexible if wanted, though I tried to keep it as straight as possible), and measured center to center from the mounting bolt head of the springs to the center of the traction bar stud/bolt. The left side is at 6 5/16" +/- about 1/32nd, and the right is at 6 3/8 +/- 1/32nd. I had to hold the rule at an angle on each side, that's why I'm +/- a 32nd. Hope this helps you out, let me know if you need anything else. Bill
            Bill... THANK YOU! Just what I needed.
            See what happens when you sell me a rear end with traction bar mounts?
              Matt -
              A quick note about Studebaker traction bars...
              By design, they will not stop wheel hop in most conditions.
              To be a more stable platform, they should be down by the spring for better support.
              So...if/when you get wheel hop, it shouldn't be totally unexpected. I've seen it happen, first hand.
                Originally posted by Mike Van Veghten View Post
                Matt -
                Mike, thanks for the insight, though the fun of this project will outweigh any performance gain. It’s more of a “the body is off the frame, and the rear end has traction bar mounts, so why not install the bars....” sorta thing.
