I am trying to address some small oil leaks on the transmission, including one coming from the shaft of the rear shift lever. Below is a picture of the shaft with the lever removed. There is suppose to be an oil seal right behind the lever. Is my arrow pointing to the seal and if so do I just jet some sort of hook to pull it out. It is very hard (looks like metal) and the replacement seal I have is a very stiff rubber (I cannot squish it with my fingers). Before I possibly break something or worse I wanted to ask if I am looking at the seal and if prying it out is the best method? Thanks.
Oil Seal for T86E shift lever
Tags: None
The only other option is to open the trans, disassemble it to get the lever out, then still have to pry the seal out. It is a challenge, but can be done. Be careful not to scratch the shaft. I also have had the roll pin holding the shaft in, leak. A dab of Permatex fixed that.Ron Dame
'63 Champ
Thanks Ron. Wow, you have to disassemble the trans to change an outer seal. Someone wasn't thinking. You would think an Italian designed it ("form over function", no offence to Italian car designers as their designs are world class).
