P/S Pump Pulley Removal Tips
  • Steering: P/S Pump Pulley Removal Tips
    I want to rebuild the power steering pump on my '64 Avanti. I have it off of the car and now I cannot get the pulley to budge. I have resisted putting a puller on the pulley due to my fear of bending the pulley. Do I need to drill and tap some bolt holes in the pulley? Any suggestions would be helpful.
    Tom Goesch
    They are just held on by the end bolt, and a key way with a woodruf key. Perhaps it is rusted. Try a little heat. You're going to replace the seals anyways.
    Bez Auto Alchemy
      I agree with Brad, it is not a real tight press fit, and maybe a bit rusty, and may need some "persuasion."
      If you look at the Pulley, you will see there is a built-in ring to put a puller on it..
      Check out this YouTube video on using the correct puller..
      Warning: He is passionate about power steering pulley removal.
      https://www.youtube.com/watch?v=QxYdRLE2pI0
      Lisle tool #3900. Check your local parts store they may rent this tool..
      Also a good pictorial rebuild...
      http://www.studebaker-info.org/Tech/...pspumpreb.html
      This tool grabs that ring in the center..
        Be Careful! Those flimsy tin pulleys bend if you look at them the wrong way. WD-40 a little heat, and patience. If you press it, don't use a lot of pressure and I'm sure you would want a bearing splitter. Good Luck
