Replacing a Saginaw Power Steering hose was a tough project!!
  • Steering: Replacing a Saginaw Power Steering hose was a tough project!!
    When a leak in the pressure hose of my Saginaw Power Steering got bad enough I knew I had to replace the hoses. The only way I could get to the fitting on the underside of the housing was through the opening in the firewall. I got the rubber steering column boot as far away from the firewall as I could without removing the steering column itself.
    I read the threads I could find on this project. Anne Goodman had posted a thread nine years ago on a replacement hose from The Parker Store. I took the old hoses down to them and they fabricated a new pressure hose and return hose. The fittings were different from the factory installed hoses but I thought they would work. There was no way the new return hose was going to be routed as the original one. The original one starts a rather drastic angle upwards just past the fitting. The new fitting did not allow the new return hose to start turning for at least 1 ½ inches further out on the hose and there was no way to route it per the original. It would have required running the return hose even closer to the exhaust manifold than before.
    The smaller pressure hose was able to be installed with the assistance of a pair of channel locks. A 5/8 inch hose was split and placed over the hose to help protect it from the heat of the exhaust manifold. The old return line was reinstalled. As some other threads suggested a floor jack raised the front of the car just off the front tires and the steering wheel was turned lock to lock several times to bleed the system. The car hasn’t been driven yet but it appears the new pressure hose fixed the problem with the leak.
    I found a possible source for the 90 degree block style female swivel fittings and have included a picture with this post. If I ever have to redo this project I’ll definitely try to find a hydraulic hose fabricator that can use this style fitting.
    Charlie D.
ID:	1760485Click image for larger version
ID:	1760486Click image for larger version
ID:	1760487Click image for larger version
ID:	1760488Click image for larger version
ID:	1760489Click image for larger version
ID:	1760490Click image for larger version
    Did they use 37 deg flare fittings or 45 deg? The one of these I have, had 45 deg and the hydraulic shop could not get fittings so they cut them off the old hoses and welded them onto new ends somehow.
    Jeff in ND
      Nice! At least it looks like there is room in the casting to be able to get a wrench on the fittings. Be thankfull you don't have Bendix power steering; four hoses, eight fittings, and you might, if you're lucky, actually be able to get a wrench on ONE and still be able to turn it. They must have had special Bendix made wrenches at the factory for the job; there's not enough clearance in the casting so normal wrenches or tubing wrenches won't fit and still turn, so getting them tight is a major ordeal.
        Did mine with engine out. Shop did a perfect job of rebuilding hose, but took just a little improvising.
