I have a 170 cu in studebaker and installed new fuel pump and glass bowl will not fill with fuel. I have cleaned out the tank and fuel lines prior and new gas. Help please
Fuel pump
Test the fuel pump in some solvent it should squirt fuel at least 6 feet, there is no priming required, it shouldn't take more than two or three strokes. If the problem remains you might have a pin hole(s) in the fuel line, or as Rich says the cork gasket is not sealing. You are probably sucking air some where.
By priming the carb may get it running and it may temporarily overcome the vacuum leak while running but when you stop it will not start again. I went through the same symptoms and after three fuel pumps, blowing out lines etc nothing worked until I removed the inlet line to the fuel pump and gently blew air in the line and squirted soapy water on the fuel line and it was full of pin holes, however it would run when primed.
