I bought new springs for gas lid from Studebaker International for 56 power hawk. Does anyone have a picture on how they go on?
Gas Lid Springs
Tags: None
I had the same problem, but eventually figured it out. If you type -gas door springs- into the forum search, you will find a thread started by Lou Van Anne that is titled gas door springs. It has a few pictures of the springs installed, as well as some instructions. Good Luck with them. The thread came up on page two.Tom Senecal Not enough money or years to build all of the Studebakers that I think I can.
Funny this, have been having problems not understanding why the door would not open or close all the way after I used 3-4 times, so today I went in here & looked & went at it again... & the same problem repeated itself; the top springpiece slide through its hole & it gets quite difficult to remove it. Once it was gone I went to look at my pals extra fender & saw that my holes was to big!
Seems belgian people fill up more than swedish people... Could probably & ofcourse have something to do with Josephine / the belgian car has been driven a longer amount of time. Anyway, I just unscrewed the door from the extra fender & then put it on mine with one screw to see how to place it best upp-down-&-sideways... This is what it looked like then:
(Yes the difference is coupe door on a sedan body)
So for now it's no door at all there because at highway speed the door stands right out fully open due to air pressure from under the fender.
Funny, eh?
- 1 like
Here's how I fixed Buttercup's gas door.
Removed the gas door and the surrounding sheet metal from a Mazda 6.
Took it apart.
Welded it in into the quarter panel in place of the original Studebaker gas door.
Swings sideways and has a remote control. It'll be much easier to insert the gas pump nozzle. These new newfangled over size gas nozzles were not designed for out Studebakers.
Jerry Forrester
Forrester's Chrome
Douglasville, Georgia
- 1 like
Here's another approach that is about as far from original as it can get and may not be for everyone. Use a strong magnet from a name tag! I had a bad name tag where one of the two round magnets fell off and was lost. I used the remaining strong magnet strip and the backer strip on the name tag to make a magnetic catch for the gas lid. I took the name tag strip, bent it into an L-shape, drilled a hole and mounted it to the bolt that holds the filler to the fender. I then Gorilla-glued the magnet strip to the lid and, voila!, a perfect fit!
Bill L.
1962 GT Hawk
Originally posted by jerry forrester View Posthere's how i fixed buttercup's gas door.removed the gas door and the surrounding sheet metal from a mazda 6.took it apart.
Welded it in into the quarter panel in place of the original studebaker gas door.
Swings sideways and has a remote control. It'll be much easier to insert the gas pump nozzle. These new newfangled over size gas nozzles were not designed for our studebakers.John Clary
- 1 like
John you just made my day!
Anyway, today I went & looked at the Subaru's door & inside it was way to rusty, but since I've just cut up a 70's japcrap biketank to make a bubble over the hole in Josephine's hood I then also cut out the quickfill tanklid with a lot of steel around it, so I might go for that & higher up, behind the rear window.
I looked several times trying to find THIS solution to my gas lid spring question, I had about given up when I decided to look tonight, as my old boss said, "even a blind squirrel gets a nut once in a while" and this was the nut I was looking forIt took less time to put the springs in than walking to the shop to do it....once I knew how............THANKS!!!!!!
On a side note, I have three Hawks and the 53 Coupe I am building and between all of them I had three springs!!
