do the high output r series cast headers clear the steering of a 1952 commander?
cast headers on 52 commander?
'52 Commanders that are original, have the Saginaw Manual Steering Gear a very good one, however it may be a bit larger than the Ross Type.
Sorry I do not know if R3 Headers will clear, they very likely will be very close if they do.
I would hope the Headers are going on a '55 to '64 or at least '55 and Later, Larger exhaust port Heads.
Mine barely clear the Saginaw Manual Box in my '54 Champion Starliner with a 299 V8, but that is Apples to Oranges, NOT the same.StudeRich
Originally posted by StudeRich View Post'52 Commanders that are original, have the Saginaw Manual Steering Gear a very good one, however it may be a bit larger than the Ross Type.
Sorry, can't help with the header question.3H-C5 "The Blue Goose"
Do the R series cast headers really qualify as high output? I'm not sure the flow rates are much better than stock manifolds. Not, at least without some major reworking with a grinder and enlarging of the outlets. And even at that, will they be enough to overcome the built in shortcomings of the Studebaker heads? This has been an ongoing point of contention ever since they were originally installed.sals54
But the "R" headers look cool Sal.
There are two different Ross boxes used by Studebaker. The SL-54 used in later cars (IIRC '58 up) is MUCH larger than the earlier TL-12.
The "R" series headers EASILY fit in my '62 with the big Ross SL-54 box, and with either the tall or short engine mount. One drawback to the "R" headers is, it's very difficult to use a headpipe any larger than 2" and even that requires some finesse. If real performance is the desired result, I'd recommend finding or building some tube headers with a larger collector. Perhaps a bit of tweaking of a Ford or Cadillac header.sigpic
[quote]Sals54 asked: "Do the R series cast headers really qualify as high output? I'm not sure the flow rates are much better than stock manifolds. Not, at least without some major reworking with a grinder and enlarging of the outlets. And even at that, will they be enough to overcome the built in shortcomings of the Studebaker heads? This has been an ongoing point of contention ever since they were originally installed."Originally posted by bensherb View PostBut the "R" headers look cool Sal.
jack vinesPackardV8
Originally posted by Buffalobill View Postwhat about big valve heads, ported by nash? more than bling, or should i stick with building a new set of headers?
Is the engine supercharged? If so, on a 305" supercharged with ported heads, into a full length exhaust system and mufflers, R3 headers might add ten horsepower. Really well built tube headers, maybe twenty.
jack vinesPackardV8
[QUOTE=PackardV8;1154544]Sals54 asked: "Do the R series cast headers really qualify as high output? I'm not sure the flow rates are much better than stock manifolds. Not, at least without some major reworking with a grinder and enlarging of the outlets. And even at that, will they be enough to overcome the built in shortcomings of the Studebaker heads? This has been an ongoing point of contention ever since they were originally installed."Both for true. Yes, the R3 headers are all we have for the Stude and do bring a bit of bling. No, on stock heads through the mufflers, they add zero horsepower.
jack vinessals54
Originally posted by rkapteyn View PostThe SL-54 is a Saginaw box that Studebaker bought from GM after Ross went on strike and no steering boxes were available.Studebaker continued using Saginaw on Champions and after the strike , used Ross on the Commanders.
on it's side cover. I'll have to look when I get home. I have both boxes, they're obviously different.
What strike do you refer to? Ross moved it's opperation from Detroit to Tennessee in late 1961. I can imagine that would reduce parts availability for a while.
Maybe Studebaker had license to the Ross design and had Saginaw produce it?sigpic
Originally posted by bensherb View PostMy manual says nothing about it being a Saginaw box. I can't find a single photo of any Saginaw box even remotely similar to it, or using the Ross system or one remotely like it, they all use the typical Saginaw system. Nor can I find the notation, SL-54, in any reference to anything Saginaw. The large box works on the same system as the small TL-12 box, it's almost identical, just much more heavy duty. It and everything in it is about 30% larger. I'm pretty sure it even has ROSS embossed
