Losing power to coil when key is released from "start"position
I agree with Gary, I believe there is a problem with the pink resistor wire between the ignition switch and the positive side of the coil. If the engine runs with the key in the start position and stalls as soon as the key is released, it's not likely that there is a problem with the ignition switch. Bud
If there are two wires on the solenoid, like older model GM products, and you have had them disconnected, they may be switched. Just a possibility.
It is the Switch, try wiggling the Key just before and after the "Run" position and check the Turn Signals or Heater Fan, I'll bet you have Power then.
The Chicom replacements do that.
Note that leaving the Jumper ON and turning the Key OFF does not prove anything, it will run as long as that wire is attached.
Do not leave the wire on long, as it is giving the points the full 12 Volts for Starting only, and will damage them.Last edited by StudeRich; 04-05-2019, 01:13 PM.
My 64 GT will fire up when I turn the key to start, but loses power to the coil when the ignition switch turns back from start to the on position. If I jump a wire from the battery to the coil, it runs but will die if I disconnect. Also if I leave the jumper wire on and turn off the key it still runs. I think it's the ignition switch failure, but could the pink resistance wire to the coil have failed? Doesn't seem likely to me.Tags: None
