The automatic transmission on my 63 Hawk makes a whining noise when in park or reverse. It shifts fine when driving. It is worse if parked on an incline. Anyone have ideas as to what could cause that
Transmission noise
Tags: None
Welcome to the SDC and to the SDC Forum Terry!
You have Low Oil or a Low Throttle pressure adjustment, which COULD be caused by Bad Engine mounts or replaced without re-adjustment.
Use ATF Type "F" for Ford, and check warm in DRIVE, wheels blocked, Prk. Brake set.
Verify that the Left Rear Engine/Trans. Mount has the 5/8" thick Cast Iron SPACER between the Frame and the Mount.Last edited by StudeRich; 04-03-2019, 12:54 PM.StudeRich
ditto. That's how youcan tell you're a pint low!! If it has F or FA in it use that. If not use Dexron which is sorta-kinda type A. Type F will move the shift from 2nd to hi up about 10 mph so its preferred by those who like acceleration (and who doesn't) Always check fluid after car has warmed up a bit so that fluid will be pumped into torque converter. If you check it cold you will get a falsely high reading on your dipstick
Originally posted by toliver View PostThe spacer is missing, and I am uncertain as to where to obtain one. Thanks to all for the good advice.
It would be interesting to know WHERE you got the Spacer and how it came to be missing.
Engine Rebuild?
Transmission Rebuild?
Engine Mount replacement?
Car was never correct since purchase?
Or WHEN the noise developed?StudeRich
