My "new" '52 Commander with the V8 does not have an oil filter but I would like to install one. I am going to a swap meet this weekend (probably Friday) where I might be able to find one. Problem is, I don't know exactly what one looks like, and how it mounts to the engine. Can anyone show me a good picture, or three of the filter can and mounting bracket I need? I will much appreciate it. Thanks.
oil filter for my '52 Commander V8
It was a Fram F4 Canister Type that uses a C4 drop-in Element, Orange with a Black Lid or Solid Black.
You would have to find one from a Studebaker V8 with the mounting Brackets to make the install ON the Engine (Oil Filler Pipe) like an Original, and neater.
It would be better to buy it from a Studebaker Vendor or a Forum Member here.
There is a For Sale/Wanted Forum here.
Please refer ONLY to post #3 over here: http://forum.studebakerdriversclub.com/showthread.php?110236-Oil-filter-canister-color&highlight=Oil+Filter
There is WAY too much off Topic back and forth on the rest of that string that will not help you.
This NOS kit is on Ebay but it lists for a 55-57. Maybe it would fit yours?
https://www.ebay.com/itm/NOS-1955-19...53.m1438.l2649
Originally posted by Mark Klinger View PostThis NOS kit is on Ebay but it lists for a 55-57. Maybe it would fit yours?
https://www.ebay.com/itm/NOS-1955-19...53.m1438.l2649"In the heart of Arkansas."
Fram is incorrect, these Kits were Studebaker Factory Correct on 1958 to Early 1962, but I do see that it was printed in Late 1956, so they did only know about up to 1957 Models, I will give em that, but still incorrect about '55 to '57.
Will they WORK on ANY Stude. V8?
Sure, only minor adjustments and Parts are needed for some years, like an Aluminum, taller, straighter Oil fill Pipe from a '61-'62 if desired.StudeRich
Thom,
If you plan on keeping your "new" '52 Commander for any length of time, I would recommend you purchase a Chassis Parts Catalog and a Body Parts Catalog, along with the 1951 Shop Manual.
Page 29 in the Chassis Catalog shows all filter kits used in models from 1951 through 1954. And from the body tag on the firewall you will note yours is a model 3H.
'33 Rockne 10,
'51 Commander Starlight,
'56 Sky Hawk
OK, I probably will pick up some more manuals. I have some Studebaker books already, but none that cover the '52 Commander in detail. I plan, God willing, and weather permitting, to attend the spring Autofair this weekend at the Charlotte Motor Speedway in Concord NC. There should be some books and manuals available there. In the meantime, I also need to know how the oil filter can is plumbed to the engine. Are there two lines/pipes/hoses? Or direct connection? Thanks.thom
Originally posted by thom View Post...spring Autofair this weekend at the Charlotte Motor Speedway in Concord NC. There should be some books and manuals available there.
The books are available in new print, or can be found at swap meets or on line auctions; or all in a bunch on one CD-ROM for about $20, though the resolution on the CD isn't as good as the printed versions.
'33 Rockne 10,
'56 Sky Hawk
My recommendation is to not install an oil fiter. The car did just fine for 67 years. Also, the oil and its additives are much better now than they were a half a Century ago. Also, you will probably be changing the oil frequently and driving the car gently.Gary L.
I'm not so much concerned about having the filter for the actual function as the "looks" of it being present on the engine, really. Is that silly?
That's like having a perfectly good running engine and then paying money for decals to stick on it, huh?
Or changing heater hoses because they are not the color that were on the car from the factory.thom
