I have a T10 from a '63 hawk that I would like to put into my '59 silverhawk. Currently my car has a 3 speed overdrive and I am wondering what I will need to do the swap? I know it will need a different driveshaft, but will the cross member and bell that are in the car work?
T10 swap
Tags: None
A original T-10 from a ‘63 - ‘64 Studebaker has the same bolt pattern as your 3 speed. Thus you just have to install a longer driveshaft, cut a opening for the floor shifter, and use the correct speedometer cable housing, neutral safety switch, and back up light switch.
(Not stated, but I assume your ‘59 Hawk is a V-8)
Originally posted by jrlemke View PostHow about clutch linkage? Doesn't the inner end bolt to the trans on the four speed?- Jim
So, yes you will need a fairly unique and rare clutch shaft support bracket as used on ‘61- ‘64 4 speed Hawks - also used on earlier Hawks with the T-85 Heavy Duty 3 speed, but that application is quite rare.
Yes, my car is a v8 and all I got with the t10 is the trans itself, and a stock shifter with linkage, oh and the yoke.
Can I use the stock starter? I'll have to look into the clutch shaft support bracket... it could be something I could possibly make if I can't find one. What about the crossmember? Will the one on my hawk work?
Not only the shaft support bracket, but the shaft itself is different too. Almost all of the clutch pedal linkage parts are specific to the 4 speed. The driveshaft is a different length too.
I’ve been gathering up the same parts for an upcoming project, most of it is pretty scarce. I’ll post some photos later today so you can see what you need.
I have a T10 from a '63 hawk that I would like to put into my '59 silverhawk.Originally posted by paul shuffleburg View PostWould he have to think about changing the ring & pinion going from a 3-speed OD to a 4 speed?
The '59 Silver Hawk with overdrive would typically come with a 3.73 rear gear and 2.61 in overdrive. With a 4-speed, that's great for acceleration off the line, but maybe too busy for cruising. A 3.31 or even 3.07 would be better if many highway miles are anticipated.
jack vinesPackardV8
Originally posted by evilhawk View PostYes, all I got with the t10 is the trans itself, and a stock shifter with linkage,
jack vinesPackardV8
