Dual exhaust rear gravel pan for a '51
  • Body / Glass: Dual exhaust rear gravel pan for a '51
    The rear gravel pan below the rear bumper of my '51 Champion is notched to provide clearance for the exhaust pipe, but I'm about to put a split exhaust manifold on the flathead six and run dual pipes all the way to the rear. Were there ever any rear pans used on the V8 cars that had two notches for dual exhausts, something that would fit my car and save some fabrication? Perhaps the V8 cars never offered dual exhausts because of the added expense. Would someone let me know if I'm looking for a part that doesn't exist from the factory. Thanks.
    Right; no such animal was ever stamped by Studebaker for cars prior to the 1955 model year. BP
      I may put a pan on my 52, but it will have to be a custom build. I thought I could use a stock pan and make a left notch, but I found out when Leonard moved the gas tank to the middle and added dual pipes, the right side is in the wrong place.
      For now people just have to look at the chrome diff cover.
        I gave a little, but never a lot, of thought to adding duals to my '51 Commander.
        But what I thought about doing was running both pipes on the right, side by side (avoiding any hot pipe near the fuel tank), and fabricating a dual tip that would exit without altering the gravel guard.
        By initiating the change at the crossover pipe, I believe it would be a straight shot using two pretty identical intermediate pipes and perhaps piggy-backing the mufflers, rather than side by side and, since both pipes would only be exhausting four cylinders they, as well as the mufflers, could be smaller than stock diameter.
        Having NOT done it, I'm sure some other issues would be encountered.
        Brad Johnson,
        '56 Sky Hawk in process
          [ATTACH=CONFIG]79646[/ATTACH]
          Sorta like this? But run 'em parallel all the way back. This is what was on Buttercup when I bought him.
          Jerry Forrester
          Forrester's Chrome
          Douglasville, Georgia
ID:	1725792 And with those glass packs they could still be side by side.
            Brad Johnson,
