Engine Identification
  • Engine: Engine Identification
    I have an engine that’s been sitting around for more years than I can remember, but am having a problem identifying it. I know it’s pre ‘62 since it’s not a full flow block.
    The number stamped on the ID location of the block is PH38.
    I’m also guessing that it’s a replacement block.
    Thanks for the help.
    Something is either missing, incorrect, or mis-stamped.
    http://www.studebakerdriversclub.com/V8EngineID.asp
    Skip Lackie
      Here’s a photo of the identification pad on the engine.
        I have a feeling the photo won’t be very large or clear for any of you. I haven’t had any luck uploading photos to this site from my iPhone. But I am 100% sure it is stamped PH38. Only thing I’m not sure of is whether there is a 1 at the end of it or not.
        What especially confuses me is that it is most definitely NOT a full flow block. There is no oil filter mounting pad on the side of the block.
          Perhaps it was an earlier replacement block in a 1964 car using that car's engine number (stamped on a blank block). However, the stamping does look factory.
            Are you sure it is not full flow? Maybe there is just a block off plate instead of the filter adapter.
            78 Avanti RQB 2792
            64 Avanti R1 R5408
            63 Avanti R1 R4551
            63 Avanti R1 R2281
            62 GT Hawk V15949
            56 GH 6032504
            56 GH 6032588
            55 Speedster 7160047
            55 Speedster 7165279
              I’m 100% sure it’s not full flow. There is no block off plate covering an oil filter mounting pad.
                What is the block casting number at right front across from engine number?
