Speedometer light bulb wiring 'harness' for a 1951, 2R5... is there such a thing?
  • Speedo/Tach/Gauges: Speedometer light bulb wiring 'harness' for a 1951, 2R5... is there such a thing?
    Hi Guys,
    Is there a speedometer light bulb wiring 'harness' for a 1951, 2R5 pickup? There are three bulbs and wires going into the speedometer.
    Thanks for your replies,
    Mark in Ohio
    2nd time around: the wires necessary for complete install are likely to be had/found in a new reproduction wiring harness. There are several vendors for that. If you don't want to pay the big bucks, you can easily make your own with the help of a wiring diagram found in the shop manual which you should have for you and your mechanic to answer this and other questions concerns on your truck.
    I replaced my bulb circuit(s) with 12 volt wires and bulb holders from a later Lark. All you need to do is wire them correctly through the headlight switch....
      Thanks Jack B, and sorrt I missed it first time around. I see where you replied last week. I called Studebaker Internationl but they don't stock it. As suggested, I'll try another vendor.
      If anyone knows of a vendor that has one for sure, please let me know.
      Studebaker part number is Speedometer Wiring Harness #677364
      Thanks again,
      Mark in Ohio
        I believe Lark Works can make partial harnesses.
          Thanks Tim and everyone else. I just ordered the wiring harness from Lark Works and I look forward to getting it soon.
          Thanks again,
          Mark in Ohio
            Just the piece you need or a whole harness?
