Engine misfire and not running well
  • Engine: Engine misfire and not running well
    davs studebake engine misrif and dont run well when im over 80 kmh' and when i drove it down roada back fire sound hering.is it carburetor fuel pump or rotor
    Have you checked to see if all the spark plug wires are in the correct order on the distributor and at the spark plugs?
      Are the valves adjusted properly?
      Is the ignition timing adjusted (4 degrees higher than the book) ?
      Are the spark plug wires, distributor cap and rotor in good condition ?
        Oll the spark plugs are new i will ceck the thing tjet you wrtoth
          Check that all of the spark plug wires were completely put back onto the plugs and also that the wires are on the correct plugs.
            Remember that the Firing Order in the Distributor Cap is COUNTERCLOCKWISE.
              Make sure #1 and# 5 plug wires and #3 and#7 are bundled together to prevent induction of energy between wires and crossfire.
              https://forums.aaca.org/topic/25443-...dle-roughness/
              http://www.studebakerclubs.com/North...ers/HH1502.pdf
                "engine misrif and dont run well when im over 80 kmh' and when i drove it down roada back fire sound hering"
                When driving at lower speeds, what happens if you open the throttle to half open or more?
                Is the back fire form the exhaust, or the intake ?
                Did it ever run well?
                  Oforstudebaker, check the inside of that dist. cap it may have carbon tracks causing the problem. also you may have water in your fuel. Luck Doofus
