Wagonaire fixed window seals - What to use?
  • Body / Glass: Wagonaire fixed window seals - What to use?
    I understand that the side window seals in the cargo area of Wagonaires are NLA.
    What are the Wagonaire guys using for gasket repalcements?
    Thanks in advance
    Jamie McLeod
    Hope Mills, NC
    1963 Lark "Ugly Betty"
    1958 Commander "Christine"
    1964 Wagonaire "Louise"
    1955 Commander Sedan
    1964 Champ
    1960 Lark
    You are correct , no one is reproducing them .
      Contact a glass shop that does hot rods. They will have a generic rubber molding that will work, and might even look very correct.
      1950 Champion Convertible
      1950 Champion 4Dr
      1955 President 2 Dr Hardtop
      1957 Thunderbird
        I'm re- using mine. If you study how it all goes together, you may notice all the gasket did was prevent breakage. I think the glazing compound made the seal, and that big moulding hid the mess! Any water leakage went into the little slot and into the 1/4 panel. I doubt they can leak worse than the roof. good luck.
          Mine just crumbled when I took the glass out. I'll come up with something.
          Jamie McLeod
          Hope Mills, NC
          1964 Champ
          1960 Lark
            Excellent advice.
            There is also Steele rubber products.
            https://www.steelerubber.com/dense-extrusions
            Vendors will often send short sections of their products for a nominal fee, so you can see first hand what will work for your application.
            60V-L6 - 60 Lark convertible
              You might also try Restoration Specialties ( Supply ) in Windber, PA. That is where I got the gasket pieces for my '64 SR wagon.
              Rob in PA.
