flathead six exhaust header
  • #16
    I ran across this picture in my files. It might help with designing yours.
    • #17
      Originally posted by dstude View Post
      If someone will explain how to add photos to a post, I'll add some pictures of the Morgan intake (and the head, if anyone is interested). Both are very nice pieces. I just haven't seen any of the common icons for adding a photo to the posts. Thanks.
      Click the icon that is a picture of a tree (3rd from right) and follow the prompts. "from computer", "choose file", then "upload file".
      • #18
        You could make some short spacer blocks to push the Morgan out far enough to clear the curved tubes of a steel tube exhaust header.
        Hang in there... You'll get it done!
        Sounds like a neat project.
        I did up a Morgan dual ace and a Morgan head a while back. The Morgan intake is indeed short and close to the block.
        • #19
          Thanks for the tips on uploading photos. Here are some pictures of the Morgan cylinder head and intake. The head is currently at the machine shop being surfaced. I don't know what compression ratio the head was designed to produce, so I hated to have to have it surfaced in case that might increase the chances of the valves hitting the head. But it definitely needed to be machined. I'll know soon if there is a clearance problem. If so, I'll need to find someone who makes solid copper head gaskets so I can get the clearance I'll need.
          Well, apparently no photos. I followed the very clear instructions and ended up with a message saying "invalid files," whatever that might mean, so I'll have to try to figure out what I'm doing wrong.
          The good news is that someone is now building a 4-into-2 header for me, and that is really the last important piece I needed for the engine project. Hopefully, by the time everything is installed on the engine I'll have figured out how to add photos to a forum post.
          • #20
            jpg, jpeg, and gif Picture Files are allowed, and there is a very reasonable Size limit.
            • #21
              Are you loading the pictures to your computer first? I find that easier than loading from another host. Just click 'go advanced' and then scroll down to 'manage attachments' click, and then click 'choose file', go to your pictures and select the one you want. Down load one or several and exit when finished. Just read and follow the prompts.
              • #22
                Yes, the photos were taken with my phone, then downloaded to a laptop. I've both emailed and texted them to several friends but cannot seem to make the SDC system work for me. I'll keep trying and will welcome any tips and advice. Thanks.
                • #23
                  On this one they went to a lot of trouble to keep all the outlets connected. If you wanted to make one yourself, you could simply use bar stock and cut each flange piece separately. Then have it welded up to fit while bolted to the block. And it does not have to be as complicated as the one you see either. A much shorter 2 into 1 Y would be just as efficient. Remember that you’re not really gaining any horse power with these. Losing a bit of weight and gaining a terrific new sound is worth the effort. Good luck.
                  sals54
                  • #24
                    My previous post with http://www.victoryheaderflanges.com/headerflanges.html
                    Update
                    They have been left high and dry from the manufactuerer of their flanges so if you know some one looking to do small runs They are looking for a co to team up with. But they did make them for us.
                    I have a 1950 4 door Commander a 51 land cruiser And a 52 Champion
                    I'll Tattoo you anytime!
                    And you can find me at....
                    New Shop Name Same tattoo shop
                    Crazy Lady Ink
                    Shakopee Mn.
                    952-445-3281
                    27 years in the tattooing biz
