My 64 Hawk has disc brakes with a rebuilt Hydrovac. After applying and then releasing, the brakes still hold for about 10 seconds before fully releasing. Is this an issue with the Hydrovac? I also installed a new master cylinder specific to disc brakes. Is it a check valve issue perhaps?
Power brakes not releasing.
The Number ONE suspect for these issues is always those pesky 2 short Flex Hoses at the Hydrovac.
They swell up internally and get Kinked, so if they are not really Fresh, you might want to replace them.
As long as your New Master Cylinder has had the Residual Valve removed from the end of the return spring and the rubber cushion in the end of the Cylinder used for Drum Brakes, THAT Should not be your problem.
The vacuum Check Valve in the Hose from the intake Manifold is just a one-way valve to hold the Vacuum only in the Hydrovac, I don't see that as a problem either.
There are no troublesome Equalizer Valves in a stock Studebaker Disc Brake setup.
How about the pedal RETURN, is the return spring and Pedal adjustment allowing a full, rapid, Pedal Return with some free play at the Top of travel?StudeRich
My ‘63 GT with disc brakes had the same problem with a rebuilt Hydrovac too recently. If I would give the brake pedal a quick “stab” the brakes would release. Issue turned out, for me, that a seal inside the unit failed allowing brake fluid to be sucked in to the engine. As soon as I got a replacement unit my problem was gone. Check the vacuum line going to your unit and see if there is any brake fluid there, mine was coming out in a steady drip.
