bearing retainer for t10
  • Transmission / Overdrive: bearing retainer for t10
    Found this on eBay if someone could verify that it’s the correct one?
    https://rover.ebay.com/rover/0/0/0?m...2F273480556298
    Or if anyone has one for sale, I am a buyer.
    Thanks
    Charles
    Charles
    1961 Lark Regal VIII 259/auto -- Lucy
    I would ask the seller if the throw out bearing portion of the retainer is 1 1/2" in diam. That part is narley looking. Rusty, funky and over priced already. I would put up a want add on the board here or call A&A gear on Washington Blvd. in L.A.
      Same as a T85.
        I may have a NOS one , I will check tomorrow , Ed
          Originally posted by DieselJim View Post
          Same as a T85.
          cool thanks
          That would be nice, shoot me a PM if you find it. Thanks ED
          Charles
            Hi PM sent , Ed
              Hi PM sent , Ed
              Thanks for checking Ed.
              To all - still looking for a bearing retainer. Anybody got one?
              I guess should probably take advantage of the classifieds.
              Charles
                If the Super T10 works, they are like $30 and readily available. But the ST10 might have a bigger bearing. I think if you hit the internet you should be able to find one under $50.
                I know I have 1 spare. If I have a few spares, I'd sell one.
                  Caveat Emptor - Let the buyer beware. Ford also used T-10's and T-85's.
                    The Ford has a throw out bearing with a 1 7/16" ID. The Chev. is 1 3/8" and the Stude is 1 1/2".
                      To bring this back up.....
                      I have been thinking about swapping the t10 I have into my Lark. I have also been looking at hydraulic throwout bearings.
                      Being that I am leaning on going hydraulic for the throwout bearing, if I want to install this, I should be able to get a Chevy ( 1 3/8) bearing retainer and be good to go if I get the 1 3/8 throwout bearing. No?
                      Charles
                        Do you already have a clutch pedal?
                        Hydraulic is never as good as Studebaker mechanical. Is it a 61 Lark with floor pedals? They are the very best for precision clutch action - you can feel the throwout bearing tapping on the cover fingers. If it has suspended pedals, there is a bell crank which pivots on the inboard side of the frame. This is OK for a stock type clutch - HD racing clutch another matter. Still, I'd get the pieces for this. If you are missing the clutch pedal entirely, I'd still get the conversion pieces - the floor mounted would be easier to convert.
                        If using a Chevy, get the Chevy style Studebaker bell housing and all you'll have to do is get a Stude front bearing retainer and turn a simple bushing for back of the crank.
                        AND it would be all stock too.
                          Yes, but get the HTOB that is held to the retainer with bolts. I have used the McLoed units that have O rings and they let the TOB jerk back and forth. After a while the hoses start leaking.
                            Curious what the casting number/s is on these, and what goes bad on them?.
                              Usually, it's the throwout bearing and/or the forks causing the bearing ID to drag and rattle against the nose of the retainer.
                              jack vines
