1960 Lark v8 conv. leaf spring front frame mount upper or lower holes? I looked at an Avanti one was upper and one was lower. Thanks Mark
60 lark leaf springs
Tags: None
That is Correct.
This compensates for the excess Weight on the Left: Battery, Steering Gear, offset Fuel Tank and Driver.
It also helps with the Right side Torquing Down on acceleration.StudeRich
If the engine torques down to the right on acceleration, why does the air cleaner stud hit the hood when the right side engine mount "isolator" breaks under accelleration? Why is the right side isolator the one that breaks? Shouldn't it be in compression?sigpic
LEFT and RIGHT are defined as you are sitting in the front seat, so in the U.S. the left side is the driver's side.
If you are standing in front of the car looking at the engine, the crankshaft is turning clockwise, so the engine torque is pushing down on the right side.
The torque is trying to twist the block opposite of the crankshaft rotation.
Originally posted by gordr View PostIt's usually the left side front mount that parts in tension. Which is the one on your right hand as you stand leaning over the radiator.Originally posted by TWChamp View PostLEFT and RIGHT are defined as you are sitting in the front seat, so in the U.S. the left side is the driver's side.
The torque is trying to twist the block opposite of the crankshaft rotation.. The left (drivers) side one is 56 years old as far as I know.
It does seem strange that the right one would break. I've never had any broken Studebaker mounts, but in the 70's I had to replace several broken mounts on GM cars, and also do the safety cable recalls, where a cable was wrapped around both halves of the mount, so it couldn't lift up and cause sudden acceleration.
The right side would break if you were hard on the go pedal in reverse or perhaps rocking the car out of mud/snow.59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
Originally posted by Warren Webb View PostThe right side would break if you were hard on the go pedal in reverse or perhaps rocking the car out of mud/snow.
I've since added two mounts at the rear of the engine (bellhousing flange) and they're all thru bolted urethane now; even if the "insulator"(my mistake, they call the motor mount rubber an "Insulator" not Isolator) goes away nothing can hit the hood now.sigpic
Back to Leaf springs...I'm to understand the forward part of the left leaf spring is to mount in the lower hole and the right side in the upper hole on my '62 Hawk correct? I wish I had known when I replaced the leaf springs; I put the bolts in where they came out thinking that was proper. Comments?
Originally posted by chet445 View PostBack to Leaf springs...I'm to understand the forward part of the left leaf spring is to mount in the lower hole and the right side in the upper hole on my '62 Hawk correct? I wish I had known when I replaced the leaf springs; I put the bolts in where they came out thinking that was proper. Comments?sigpic
