Running rich
Agree! Could easily spend much more than the cost of an Edelbrock trying to make a Holley work and it will still be a troublesome Holley. I thought Pertronix was very reasonably priced.
Originally posted by bezhawk View PostWhy is everyone GUESSING what is best for a particular engine? Do yourself a favor and buy a wideband Oxygen sensor and gauge. It is the ONLY way for sure to know what is going on in the combustion process. In the years past it was possible to read the plugs and kind of get close. You can't do that with the formulations of fuel currently being sold. ANY carburetor will work if you dial in the A/F ratio for that particular engine. In other words the engine doesn't care what brand is on it as long as it is calibrated for its needs.
Would the Edelbrock be a bolt on item or will I have to buy a new inlet manifold / adapter? Sorry if I sound daft but this is my first dabble with American cars and I have little knowledge of interchangeable parts.
Could it be as simple as a ruptured power valve diaphram? Luck Doofus
Not a Holley fan either, but if it's relatively new, you probably can make it run right, if you spend enough time on it. Job #1 is to check your ignition. If it still has points in it, make sure the dwell is correct, and that both centrifugal and vacuum advance are on spec. If the ignition system is out of whack, no amount of fiddling with the carb will make the carb run right. Next, check the choke mechanism. Manual or automatic? In either case, does it open fully? Then check the carb floats.
Originally posted by LarkingAround View PostYeah someone else sid that to me today. I thought they were the carb every V8 owner wanted, seems they're not as well loved as I thought.
I'm told my Holley is a 600 and I would be better off with an Edelbrock 500. Does that sound feasible?
Running rich
My 63 Lark 289 has a Holley 9834-2 carb on it and it seems to be running very rich. I just pulled a plug and it's sooty black.
Do I have to buy a jet kit or is there any adjustments I can make to lean it out a little?
When I first start the car, even after a couple of weeks, it fires first time and idles OK but as soon as I drive away it splutters until it revs out a little. Then it dies at stop lights and junctions. Strange thing is, if I stop, leave it for an hour or so then go back and take it for a run it seems much better. It always has a flat spot just off idle though. This is one weird car......Tags: None
