How to tell a six volt compared to a twelve system
  • How to tell a six volt compared to a twelve system
    How can I tell if a car (pre-55) has been wired for twelve or six volt?
    Home of the famous Mr. Ed!
    Lotsa Larks!
    Ron Smith
    Ron Smith
    Check the voltage regulator and generator. Whatever is stamped on them will tell you what voltage the car is set up for. My houseguest provided this info for me to type to you.
    Mabel 1949 Champion
    1957 Silverhawk
    1955 Champion 4Dr.Regal
    Gus 1958 Transtar
    Fresno,Ca
    Mabel 1949 Champion
    Hawk 1957 Silverhawk
    Gus 1958 Transtar
    The Prez 1955 President State
    Blu 1957 Golden Hawk
    Fresno,Ca
      April first is a ways off....
      Follow the battery cable from the block to the battery.
      If it is hooked up to the '+', then it is a correctly wired pre-56 6 volt (positive ground) system.
      If it is hooked up to the '-', then someone has jammed a 12v battery in there (and you will see stuff disconnected, or added voltage drops (resistors, etc).. You'd most likely see a ballast resistor in the primary distributor wiring also...
      Ron Smith
