As part of my ongoing '51 Champion Regal overheating issue - or at least running at "H" but not boiling over - I've finally reached for my company's T400 FLIR camera to take some thermal images. See pics attached below.
Due to dragging brakes, I sorted through the brake system, replacing only the hydraulic lines with stainless steel and several flushes to rid the crud and rust. Then I replaced the thermostat/collar/gaskets, gave the block a good flushing, tested the sending unit (down to ~0 ohms at 190-195 F) and made sure the timing was correct.
Interesting to see how the upper tank takes the coolant initially via the upper hose (violet is cooler, red to orange to white is hotter). Ignoring the "shadow" created by the spinning fan, it seems to me the center cores of the rad are not taking coolant, even after these "hotter" photos were taken after a short run around the block. Prior to sending the core out for testing, has anyone sent an anti-scale or similar boilout through their old radiators?
Curiously if the gauge itself may be suspect - the block looks uniformly heated in the picture but I'm troubled as to why the gauge should read so "hot" so quickly, typically within 10 minutes at 80 degF outside, etc.
Any comments would be welcome.
