I'm about to break into the brake system on my 62 Lark Daytona to replace the master cylinder with a dual piston unit and replace the rear flex hose. I was thinking about switching from DOT 3 fluid to DOT 5 fluid since I'll be having to completely refill the MC, replace the original single brake tube coming off the MC, installing a new, second tube off the MC, and replacing the rear flex hose (I'll be introducing a lot of air in the lines that will need to be bled out).
I've seen some posts on the Forum made by others who've switched from DOT 3 to DOT 5 by simply making sure all the old fluid was flushed out of every component and refilled and bled with DOT 5.
Question: If I do not replace the wheel cylinders that have been used with DOT 3, will I have any problems down the road with the seals failing in the wheel cylinders after the switch to DOT 5?
