Which Head would be better?
  • Engine: Which Head would be better?
    I have a set of 535976 & 537555 and I'm trying to decide which set to put on a 259. Thoughts?
    Jim Kaufman
    Kearney NE
    1952 2R10
    1953 Champion (sold it and still kicking myself)
    1962 GT Hawk
    1963 R3984 Avanti R1
    The 555s will be about a 1/2 point higher in compression. Still would be regular gas either way, but better performance. About 8.5 with a shim gasket. 8:1 with composition gaskets.
    Bez Auto Alchemy
      I expect from 7.5 to 8.5 is about a full point, if you want the factory rated H.P. unless it is Supercharged, do not use the 535976 Truck and '57-'58 GH Heads.
        The difference of a full point would only be IF you used the thick head gasket on the 976 head, and the SHIM gasket on the 555. If you use the SAME TYPE gasket across the board, then the difference is 1/2 a point.
        Bez Auto Alchemy
          Studebaker V8 head casting info is here:
          http://www.studebaker-info.org/Headcasting.html
            http://www.studebaker-info.org/text3/Headcasting.html
            EH....TILT That's the old version
            Here's the latest
            64 GT Hawk (K7)
            1970 Avanti (R3)
              Thanks. I updated my erroneous info from a not properly updated link.
              Next time, you provide the info
              Here's the latest
