Climatizer air duct route 54C Commander
  • Cool/Heat: Climatizer air duct route 54C Commander
    On my 54 C where exactly does the air duct hose from the Climatizer blower motor to heater core duct tube go ? Does it go in front of the cowl to frame body mount bolt ? When I place it here it rubs the heat riser valve and is within an inch of the exhaust manifold. It looks to me like it would melt. Plus it looks like the tire would rub it when turning the wheels. Or does it go behind the cowl to frame body mount bolt? I have gone thru all of my manuals and I can't find a good picture or explanation as to it's routing. Another question, my heater core air duct tube it so tight against the floor board that I can't work the hose or clamp over it. Do I need to lift the carpet and loosen screws that hold the core tube? TY
    1942 Packard Clipper Custom Touring Sedan * 1952 Studebaker Champion Regal * 1954 Studebaker Commander Regal Starlight * 1967 Thunderbird Hdtp * 1969 Continental Mark III * 1969 Mercury Marquis convertible * 1972 Buick Riviera * 1973 Continental Mark IV * 1978 Glass Top Lincoln Town Car * 1983 Mercedes 300SD * 1986 Dodge RAM 4WD * 1999 Infiniti Q45
    Someone asked this exact question about this exact model about a year ago, and many responses included photos, but I'll be danged if I can find it. And I believe you probably DO need to loosen the attaching screw from under the carpet to drop the duct tube just a tad, then tighten your clamp and screw the tube back up.
    In the interim, I just went to the garage and took a few I hope will help.
ID:	1721792 Click image for larger version
ID:	1721793 Click image for larger version
    '33 Rockne 10,
    '51 Commander Starlight,
    '56 Sky Hawk
      I don't know how you got it between the engine and firewall running it around the front of the firewall body mount, but it goes behind it, between the body mount and the toeboard then runs along the frame. It is tight against the floor at the heater tube, I just wedge a screwdriver between the heater tube and floor enough to get the hose on.
        [ATTACH=CONFIG]74816[/ATTACH] [ATTACH=CONFIG]74817[/ATTACH] [ATTACH=CONFIG]74818[/ATTACH]
        Thank you so much ! Your pictures cleared up what my manuals didn't. Pat
          Here's another couple.
ID:	1721799Click image for larger version
            What’s that blue support Ben?
              I put in a GM 4L60 trans, it has only a top half bellhousing. The stock rear engine mount is on the bottom of the bell housing on the manual trans I removed ,the stock auto has two at about 5 an 7 oclock, they mount to a cross member that bolts to the same 3 bolts on each frame rail mine bolts to. That stock cross member was in the way so I made my own. It's a bit lower and about 4"more rearward. It has frame brackets that incorporate rear engine mounts, and a removeable cross member between them. The rear of the trans is bolted to the "wing", which I had to trim a bit too.
                Interesting, nice job Ben.
