On a 53 K body Studebaker, what size and type are the screws that hold the rear bumper filler panel to the body? My car has a new paint job and zero hardware also is there a manual that would give me this information along with the sizes of other bolts and screws on this vehicle? Thanks for any help on this as I'm trying to put back together my car after someone else took it apart and left me without a lot of the screws and bolts required to put it back together. Thanks in advance, Darryl Lewallen
53 rear bumper filler panel scews
If I'm not sure on sheet metal screw size, I usually start with small (#4, or #6) and see if they tighten up snug. If not, just move up a size at a time, till they feel like they fit. I'm guessing that the filler panel will take a #8, by 1/2", but not positive.
There is a manual. It's called the chassis parts catalog. If you buy one and read it, you will be amazed at the amount of information contained therein.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
60V-L6 - 60 Lark convertible
That attachment I posted also shows the bolts that hold the "gravel deflector" to the frame if that is what you were looking at. The filler panel is at the top between the body under trunk lower weather seal and the bumper. Attached to body. The gravel deflector is at the bottom under bumper attached to the frame.
Note that '53's (maybe a midyear change too....) do not have the larger formed part that is painted body color and has a notch for the exhaust. Those came with '54's. I suspect many have been changed over the years.
Some prior posts on this topic (lower gravel deflector/filler):
http://forum.studebakerdriversclub.c...avel+deflector
The bolts for that part at least for the earlier version are large actual self threading bolts as per the notes.
Jeff in ND
Altair, I see from my notes I had them as 1/4-20 bolts but I am sure you are correct they are 5/16-18. I know that most every other bolt in my car was that diameter. I was able to find the right sort of bolts with those flared heads at a local surplus hardware place that often had stuff not usually easy to find. Same (except shorter) as the ones holding the front fender aprons to the core support and other places.
Jeff in ND
Thanks all for the info, think I'll just run by Fastenal or Ace and see what they have, also thanks Roy for info on the chassis parts catalog. I knew there were different manuals [ I've got two shop manuals] but I did not know which of the other ones had the information I need. I see in my SI catalog, Body manuals that include 53 cars listed under Body and Chassis manuals, is this the right one? Again Thanks all for the replies and answers.Darryl C. Lewallen Clarkesville, Ga.
There is a 53-58 body parts catalog and a 51-54 chassis parts catalog. You should get both.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Originally posted by dclewallen View PostI see in my SI catalog, Body manuals that include 53 cars listed under Body and Chassis manuals, is this the right one?
I do hope everyone clearly understands the difference between the "gravel deflector" and the "deflector, filler panel", which I believe was Darryl's initial inquiry.
Dave's photo is of a gravel deflector that goes below the bumper and attaches to the frame. That is not the filler panel, which screws to the body just below the trunk lid opening."All attempts to 'rise above the issue' are simply an excuse to avoid it profitably." --Dick Gregory
'33 Rockne 10,
'51 Commander Starlight,
'56 Sky Hawk
