Another idea for power brakes
  • Brakes: Another idea for power brakes
    I saw this on ebay and I think it might be another way to add power brakes to Studes and others. These are used on Lexus hybrid SUVs. I don't see any connection to Antilock, just 12V. Might even be able to do it under the floor. Would need 12V and under floor would need remote reservoir.
    https://www.ebay.com/itm/2007-2011-L...H0.XLexus.TRS1
    Dan White
    64 R1 GT
    64 R2 GT
    58 C Cab
    57 Broadmoor (Marvin)
    I was looking on alldata and it looks like that cylinder thing below the master cylinder is called a brake stroke simulator and it plugs into an abs/skid control module so it probably won't work without it.
      One of the large "Internet/Mail Order" brake system suppliers advertised an electric booster for around $1,000 - And, no I do not recall which supplier (last year it was advertised in many of the car magazines).
      Paultk
        Here is a quick search for a electric brake booster for much cheaper from many sources.
        The expensive one must be from Speedway they seem to have one for like $1300
        https://www.google.com/search?q=elec...w=1536&bih=728
        I have a 1950 4 door Commander a 51 land cruiser And a 52 Champion
        I'll Tattoo you anytime!
        And you can find me at....
        New Shop Name Same tattoo shop
        Crazy Lady Ink
        Shakopee Mn.
        952-445-3281
        27 years in the tattooing biz
          These are not brake boosters, they are vacume pumps that are used to provide adequate vacume for a vacume brake booster.
          David L
            DOH!
            Not all are.
            Here is the one Mentioned above
            https://www.speedwaymotors.com/Compa...BoCTJwQAvD_BwE
            Crazy Lady Ink
            Shakopee Mn.
            952-445-3281
              A better idea...just use the proper sized master cylinder.
              I've driven two and am building another Stude (brand has no bearing) with either disc-drum, or disc-disc, and used no big heavy, space wasting, ugly power booster. The disc-drum car was pretty much a normal stopping car, while the disc-disc car is a two toe stopping car.
              The floor mounted pedal length is just right, and I assume that the hanging pedals are very close in length to having a good lever arm length.
              Do a little homework and save money and space, just get the right sized master cylinder for the calipers you are using.
