pilot bearing
  • Transmission: pilot bearing
    About 7 or 8 years ago, some one posted about using a ball bearing pressed into the Stude flywheel flange to support the G/M input shaft when using a G/M trans. I can't find the post!I need the bearing p/n or the o.d. of the bearing. Thanks in advance! -Jim
    Why not just replace the pilot bushing with one of the appropriate size? If you can't find one that fits "off the rack" a Chevy one can easilly be turned down to fit the Stude crank.
      Need to extend the support into the clutch area about an inch. The snout on the Stude. is longer than the Chev.- Jim
        Check with Phil Harris at Fairborn Studebaker. It will be made out of brass.
          I remember there was a ball bearing listed.- Jim
            If I remember right it was a bearing for a Ford alternator. Maybe Craig can chime in with the thread.
              You may be thinking of a post of mine concerning using a pilot bearing for a Ford Mustang pressed into the Studebaker crank in place of the bushing. This provided a perfect solution for a FMS T5 installation in an Avanti. The bearing is identical in overall dimensions to the rear bearing in a Prestolite alternator, but is open (pass thru) with one end having a shaft seal to retain the lube.
                The appropriate extended bushing (not one with a bearing) used to be sold by several suppliers for many years. I think I still have one in the shop.
                If you need measurements, etc. to have one made, let me know and I'll try to find it.
                  If you would! I don't want to take my trans. etc. out 'till I have the parts to put it back together. -Thanks- Jim
