Engine Will Not Turn Off
  • Ignition: Engine Will Not Turn Off
    My 1949 2R5 truck, champion engine, converted to 12V in the early 1980's, universal keyed ignition switch installed at the same time, developed this last week the habit of not turning off by turning the key off, not all of the time, but most of the time. I turn it off now with the clutch then pull the coil wire to ensure that the ignition is off. I made the guess of buying a new switch, but that is not the problem. It does the same with the new switch. There is a red light on the universal turn signal switch that stays on when the ignition is on. That light turns off when I turn the ignition off, so it does seem like the circuit is deactivated, but somehow power still goes to the distributor.
    Does anyone have an idea of what may cause this? Thanks.
    Does it have an alternator? If so, what kind?
      Yes, depending on how the alternator is wired it can "feed back" and power the ignition even with the key switched off.
        You probably have a Delco alternator and it is self energizing. I have the same situation with two of mine so I put in a switch so I can deenergize the alternator.
        65 2dr sedan
        64 2dr sedan (Pinkie)
        61 V8 Tcab
        63 Tcab 20R powered
        55 Commander Wagon
        54 Champion Wagon
        46 Gibson Model A
        50 JD MC
        45 Agricat
        67 Triumph T100
        66 Bultaco Matadore
          Thank you all. The alternator is from a 1965 Ford truck. I made this conversion long before there was an internet or forum. A friend had a scrap Ford truck, so I took the parts from it (alternator, regulator, wiring harness,) made a bracket, and it worked fine until this came up. I wired it the same as it was wired on the Ford truck.
          When I turn it off with the clutch I have been pulling the coil lead to ensure no power is going to the points. If it is the alternator feeding it, then it seems that will stop happening when I stop the engine from turning with the clutch. I take this to mean that I will not have to add the switch. What do you think?
          I will return the old universal ignition switch to use. The new one looks the exactly the same as the old one, but the key went from a brass one with a nice pattern to a shiny metal one that looks like something that is part of a small child's toy - way too cheap looking.
          Again, thanks for your help.
            Turn it off with the clutch??
              The cure is to put a diode in the charge signal wire. It can be feeding back and energizing the ignition. It is very common with a GM unit. I guess it could be possible with a Ford unit.
              james r pepper
                Thanks for your further advice. I can look at that. I am not up on my electronic knowledge, but I believe I remember a diode being like a check valve, allowing one way only flow.
                Clutch turn off is engage 3rd gear, step on brake, let clutch out.
                  Ron Hall's B;ville Avanti did the same thing the first time it was started with the racing engine... on the Salt Flats! Needed to put a tail-light bulb in the system (don't recall where; it was 1988) to add enough resistance so it would shut off.
                    Do you have an idiot light, in the charging system? It is what takes care of that problem in a stock system. One side of the bulb will go to power + and the other side will go to the F treminal on the Alt. That field terminal is ground when the Alt is stopped so the light comes on. Once the Alt starts making power the F terminal changes to + and the light goes out. With both sides of the circuit being the same ,(+), the field stops being excieted and the Alt stops making power when the engine stops until it's excieted again. Come to think of it , if you're using the stock ford regulator, it could have a shorted field coil and cause the problem depending on how its wired. I usually use a GM internal regulator type alternator, they're much easier to work with.
                    Of course the easy way to assure the alternator won't be a problem like this, is to install a GM type, 1 wire alt. That wire goes to the + side of the battery and you're done, it doesn't involve anything that could affect the ignition. The GM 3 wire one will work too, just get the stock terminal plug, the larger of the two wires goes to the batt terminal, same one that goes to the battery, and the small wire goes to one side of the idiot light the other side of the idiot light goes to power; that batt terminal will work for that too if you want to leave the light at the Alt. The light can be replaced with a resistor if you want, I can't remember the value for sure off hand, but 5 ohm 10 watt comes to mind.
                    My GT currently has a Chrysler alt and and regulator, it came to me that way and is working fine, but it will be replaced with the GM if either goes bad.
                      Thanks for your advice. The truck has its original amp gage. Except for this new thing that I can get around because of having my alternate engine stop, the charging seems to work fine. I will certainly consider changing to the one wire type if something needs to be replaced.
                        It seems strange that after working fine for over 30 years you would have to add a diode to the charging circuit. I would do a bit more testing. First I would disconnect the wire coming from the generator armature at the armature terminal of the voltage regulator, then start the engine and see what happens when you try to turn it off. If it keeps running then the current that is supplying the ignition is not coming from the generator. (Use normal precautions when disconnecting the wire and positioning it so not to touch ground.)
                          Could the solenoid be stuck and be feeding thru the 12v bi-pass? Just a thought. -Jim
                            Since you have a universal key switch, you could just connect the ignition wire to the coil to the Aux connection on the switch, assuming this is hot when in the start position. If not hot during cranking, then connect everything else on the car to the Aux connection, and only the coil to the Ign position on the switch. You want to make sure the coil is not connected to any ckt that the alternator is connected to when the switch is in the off position.
                            By the way, pulling the high tension wire from the coil won't ensure the points are not getting power, it will only prevent spark from reaching the distributor. I hope you actually meant that you were pulling one of the small primary wires from the coil.
                            Corley
                              Robert, do you have an electric fan on your radiator?
                              Jerry Forrester
                              Forrester's Chrome
                              Douglasville, Georgia
