Paxton Supercharger
  • Engine: Paxton Supercharger
    When I had the 289 motor rebuilt on my '64 Daytona, it was bored .0060 over and rebuilt using an R1 cam. Re-calculating using the new bore and stroke, I came up with about 299 cubic inches.
    My question is....would it still be possible to add a Paxton supercharger to the car? If I did, would it effectively become an R2? I believe they used Paxton SN 60 blowers back in the day. Are they still available along with all the other parts I'd need? If so, where might I find them what would a project like that cost?
    Am I crazy to even consider it? Any disadvantages or known issues with supercharged cars?
    Any advice/insight appreciated. Thanks.
    David Daoust
    Stratham, NH
    '64 Daytona convertible
    I believe that you mean that it was bored 0.060 over (60 thousandths, not 60 ten thousandths).
    IMO, adding S/C would be more problems, including finding everything, and cost than what it would be worth, unless you are just interested in the visual effect when you open your hood.
      Am I crazy to even consider it? Any disadvantages or known issues with supercharged cars? Any advice/insight appreciated. Thanks.
      You didn't provide the critical piece of information - compression ratio.
      A 299" built with flat top pistons and having had the block and heads surfaced and thin head gaskets could have 11:1 compression ratio; too high for today's fuels, even normally aspirated.
      OTOH, a 299" built with dished pistons, no surfacing, thick head gaskets, could have 8.5:1 compression and would work well with an R1 cam and a supercharger.
      As previously mentioned by Gary, finding all the pulleys, brackets, carb hat and a supercharger is not as inexpensive as it once was; figure a minimum of $1500, unless one gets a steal deal. Try to buy it all at once, as getting it one piece at a time can really push up the price.
      FWIW, I've got a new Nimesh-built high output supercharger (but none of the ancillary parts) I'm going to be selling. Should you decide to go that way, PM me.
      jack vines
        If you want to build it with the 63/64 Lark or Hawk R-2 water manifold be prepared to lay out large buckets of cash.
        60 Lark convertible V-8 auto
        61 Champ 1/2 ton 4 speed
        62 Champ 3/4 ton auto
        63 G.T. Hawk R-2,4 speed
        63 Avanti (2) R-1 auto
        64 Zip Van
        66 Cruiser V-8 auto
          Private message sent.
