Very generous friend has furnished me with a used Carter 2573-S fuel pump to get the Champ back on the road. Having some trouble with the cam lever pin not wanting to come out - but I don't want to talk about twisting off three of the main body screws...
According to the shop manual, you removed the pin plug from the housing (done), removed cam return spring (piece of cake). It then states to remove the pin retainer (spring clip) and remove the pin from the housing. My cam lever does not have this pin retainer. Shop manual shows the retainer over the pin in the middle of the pin behind the return spring. My rebuild kit that arrived today had a replacement pin with a groove in the middle and the retainer clip to go there.
My thought was maybe this particular pump did not have the retainer and getting the pin out is a simple matter of tapping it out the large end where the lead plug was located. Smallest thing I have is a rat tailed file that will fit in the small hole side of the housing to tap the pin out. At this point, I have hit that end of the pin a dozen times and only managed to start to mushroom the square end of the file...keep running that saying though my mind about a 20 minute job is something getting broken away from turning into a three day ordeal...
Any insight? And thanks ahead.
