vacuum advance?
  • Ignition: vacuum advance?
    I have a 54 3R5 truck with a 259 V8 for the past few weeks it has been giving me trouble. In put a vacuum test on it and it showed 15 Hg which I believe is late timing. Today I put new plugs in it, timed the ignition and it dropped to 15Hg's again. Next I tried advancing the timing a little at a time and it went up to 19 Hg,s and dropped back to 15 Hg's. Could the vacuum advance be causing the problem? Thanks
    Have you put a vacuum pump on the vacuum advance unit and looked with a timing light to see if the vacuum advance is working?
    60V-L6 - 60 Lark convertible
      not as of yet, needed to put it up for the night and help the wife. I will try in the AM.
        try plugging the vacuum line to the advance unit. if vacuum changes there is your problem. Luck Doofus
          tried plugging the line and nothing changed. Did another vacuum test after trying to reset the timing and it went up to 16hg's any suggestions?
            Yeah, try the propane/Mapp gas trick to see if you've got a carb/intake leak.
              Have you adjusted the valves lately? Luck Doofus
                I have not heard any valve tapping but will try the propane and then take a look at the valves. It might take a couple of days because other things need to be down first. thanks
                  Have you tried adjusting idle screws. A poorly adjusted carb will affect vacuum at idle.
                  78 Avanti RQB 2792
                  64 Avanti R1 R5408
                  63 Avanti R1 R4551
                  63 Avanti R1 R2281
                  62 GT Hawk V15949
                  56 GH 6032504
                  56 GH 6032588
                  55 Speedster 7160047
                  55 Speedster 7165279
                    Well I found the problem ,after looking at other things I decided to change the distributor cap with an spare that I had. The 2 nuts that attach the pick up coil to were no where to be seen and it was floating loose. I will pull the distributor in the morning and hopefully that will solve the problem. Thanks for all the input and help.
ID:	1720876My 259 idles about 19 inches
