Tranny fluid??
  • Transmission: Tranny fluid??
    I have a 55 commander V8. It calls for type A. We all know they don’t sell that anymore.
    Dextron II??
    Thanks in advance for your answers!
    Dextron II??
    I would use Dexron and only after draining the transmission and the convertor (separate drains). Then refill properly and to the correct amount/level.
      Steve-o-Reno, these folks advertise type A. http://www.warcopro.com/?page_id=579
        Often you can find TYPE FA which is compatible with TYPE A.
        1950 Champion Convertible
        1950 Champion 4Dr
        1955 President 2 Dr Hardtop
        1957 Thunderbird
          Valvoline still makes the best ATF for Borg Warner Automatics, Type "F", you ORDER it from your Auto Parts Store.
            I am starting to think type F or now type FA might be the best choice for the BW trannys. They originally called for type "A" which was superseded by type "F", a "F"riction modified fluid. Seems to me they were engineered to use friction fluid and not the newer slippery stuff we can buy. Considering what we are driving I will sure put in a bit of extra effort to find a type F or FA fluid. It should last for 20k-30k miles which will be well past my life expectancy.
            Oh, wait... I drive a 4 spd so the above point may be moot to me, unless I find a nice GT Hawk or exceptional Daytona Wagonaire to put in my driveway!
              Ford Motor Co = Type F: 1953/64 Ford-O-Matic, 1958/72 FX/MX & 1969/89 FMX Cruise-O-Matic. 1964/76 C4 & 1966/76 C6.
                Just a personal note as I remember my experiences with the DG250. The trans is like no other, it and the Packard Ulutamatic were the only transmissions of the period to use a lock-up torque converter. I drove cars with these, starting in 1961. Most of the cars had miles on them, and the transmissions were somewhat sloppy and pretty much matched the rest of the drive train, in other words they slipped. This required that I had to momentarily lift my foot from the accelerator, to allow it to shift into top gear. Ignorance has it's own rewards, which means, in this case, that I thought that this was a normal condition. I was just happy with what I had.
                During the 70's I restored my 55 Speedster. As part of the restoration, I had friend, Ingvar Vik, rebuild the DG 250, and was able to get, and install, a NOS torque converter. Coincidentally, I bought a 55 Commander htp with the best operating DG 250 that I have ever owned. What a difference, I immediately became aware of what I had been missing! I still own that car, but haven't driven it in years. I still own the Speedster, as well.
                Now why some of this stuff might make a difference. When I put the Speedster back together, I was talked into using, fluid type F. This fluid, as I understand it, is designed to tighten up the shifts on many Ford-Borg Warner transmissions. I determined in short order, that what might be good for Fords, with no lock-up TC didn't work at all well, for my newly rebuilt DG 250. Regardless of grade I was pulling, as soon as a speed, of about 23 mph, was reached, the trans would shift into top gear solidly. No matter how much the engine lugged, it would not shift down until I floored the accelerator, thus shifting it into passing gear. What would have worked nicely for a sloppy DG, or maybe even with the extra torque of a 289, didn't seem to work very well with the Speedster.
                I might have been able to adjust the pressure, to postpone the final shift until about 30 mph, but I found that going to Dextron made a good deal of difference. If I knew that I could still get the old quality type A fluid, with the whale oil additive, I would probably use it, in a good DG. I understand and support behind type A's demise, but it does leave a void. This has to be filled by what's available. What's good for one trans, might not work for another. You may have to do some experimentation. Good luck, I hope you let us know how it turns out.
                  It seems like this thread has transitioned from the DG transmissions to the newer Flightomatic/Fordomatic styles. This could be confusing to some. They are completely different transmissions. For example, you will not find a DG transmission originally installed in a Hawk or Daytona.
                    I still get Type F off the shelf at O'Riley. I believe if that's what was called for by the manufacturer then an effort should be made to adhere to that recommendation.
                      I asked that question at a Cooperator session at one of our Stude national meets. My car is a '59 Lark VI with the Borg Warner automatic trans. The answer, from our panel of experts, was to use Type F in my transmission. That's what I've been doing and it's worked very well. I don't know enough about the DG transmissions to give a decent answer.
                      Rog
                      '59 Lark VI Regal Hardtop
                      Smithtown,NY
                        Just to clarify, I would use Dextron first before I used Ford F in my DG. I also us Dextron in all my Studebakers, with Flightomatics. In these it really does make a difference in softening the shifting character, of a well maintained trans.
                          not a Studebaker, but when i did a flush & fill on my '89 Buick Reatta, i filled the trans with 1qt. of type F the rest was Dextron. that gave her a bit of a quicker shift.
                          on the '51 i've been using Dextron but i may try type F when i refill it - which is soon since the DG-150 leaks pretty bad.
                            not a Studebaker, but when i did a flush & fill on my '89 Buick Reatta, i filled the trans with 2qts. of type F. the rest was Dextron. that gave her a bit of a quicker shift.
