11SecAvanti Did you get the Maxx or the CRT?
New HEI distributor option
When I bought my Hawk the seller had installed the mopar electronic ignition system. This consists of a mopar distributor, electronic control unit and ballast resistor all available from Chrysler parts. I also have another complete conversion unit I carry in the trunk in case any thing goes awry on a road trip. I think the whole setup is american made with parts readily available and seems to have worked flawlessly for at least the last ten years that I know of. I'm sure its just as reliable as off shore goods and probably cheaper.
My receipt for the Pertronix powered HEI distributor I recently purchased from a Studebaker vendor was $490. It did not include the coil or plug wires. That did include shipping.
And CRT does sell parts - the module is less than $20.
Excellent point, Joe.
The only reason I tossed some info up there was in response to the hardness question.
You are also correct that you have to know both components hardness number to get good life.
And to add... The hardness numbers have to be different. You cannot have the two components at the same hardness level.
That causes galling, and will destroy both components.
I have no clue as to the hardness of these items. But the buyer needs to know what he/she/it starts with and adds compatible pieces.
Originally posted by JoeHall View PostIn order for the Rockwell number on the Chinese drive gear to mean anything, we'd need to know the Rockwell of the OEM drive gear. I have no idea about Rockwells, but do know the OEM one is surprisingly soft. Seems most here are just out to bash the new distributor, but maybe we ought to wait till someone actually tests one. <snip>HTIH (Hope The Info Helps)
I have installed the distributor and has made a huge improvement on the idle. Have not test driven it yet .No Tac as wired IWill try to hook sendor to the the lead of distributor .The
I am surprise it ran 12 volts going to coil point gap .0010 burnt points. Points condenser Coil and cap would have Close to 60 bucks.
Made the HEI install on a test engine stand and no issues on install or start up. Went with the light gold spring and gold bushings for quick mechanical advance off idle. Nice and steady control timing at 2500 rpm timing. Set the static advance at 10 degrees and recorded a mechanical advance of 20 degrees for 30 total. So a 12 would give the ideal 32 degrees mechanical. Like the quick ramp up of the timing. On the wires go with any snap fit spiral core 8 mm size and cut the lengths required.Start and Stage Your Studebakers
If you run less static distributor advance the performance response will be "less." A 20 degree mechanical spread over static setting is a good zone for performance off the starting line under load. Take your car to the track and log your timing performance settings for best tune. Let the performance time slips make the call on the settings you use. Hope this helps.Start and Stage Your Studebakers
