Every year or so I embark on a failed mission to "correctly" tune and time my R2 Hawk. When I have everything set correctly according to the timing marks (12* initial, full advance comes in at about 2400 rpm, 32* BTDC on the mark, according to my non-dial back timing light), car just lacks power. I always end up adding another 12-14 degrees of distributor advance which is where it likes to run and is about 10* cooler, still starts fine. I tune it to the generally available premium pump gas junk and never get any ping or detonation, been tuning it that way for over 10 years now without issue. My question is, is that typical for R2 timing? Engine is .030 over, b&b with Erb pistons and R2+ cam with a calculated 9 1/2 :1 cr, Pertronix igniter, locked distributor, MSD 6AL, MSD 8981 timing computer, R3 headers and Erb supercharger and was built by a very reputable shop. 44-46* seems like a lot of advance for this motor but I have double checked it and I'm pretty sure my old school timing light doesn't lie.
"Correct" timing marks don't work..
On my Super Lark damper there is only one demarcation mark and it lines up only with the pointer mark at TDC #1 piston. The cam is bleeding off some of the "on paper compression prediction." The only true compression is dynamic compression values. The lower this value the more timing the engine can tolerate.
What is the cranking compression on WOT and all 7 plugs installed?Start and Stage Your Studebakers
Originally posted by 11SecAvanti View PostOn my Super Lark damper there is only one demarcation mark and it lines up only with the pointer mark at TDC #1 piston. The cam is bleeding off some of the "on paper compression prediction." The only true compression is dynamic compression values. The lower this value the more timing the engine can tolerate.
What is the cranking compression on WOT and all 7 plugs installed?sals54
This builder fixes a groove at TDC, mfgr's recommended full in advance and 3 grooves at 1/4 revolution points for easy valve lash adjustments.Last edited by 63 R2 Hawk; 11-06-2017, 05:10 PM.
The cranking compression will vary to the starter rpm. With the plugs removed the starter spins faster and gives a higher compression reading. For a baseline I stay with 7 plugs in and carb WOT. Worn rings also give lower psi readings vs a 1 to 3% leakdown tested cylinder. Leaky valves, cam overlap, valve settings, starter rpm, engine at operating temperature vs cold engine, etc. are Some of the influcing factors involved in a compression gauge test.
But again, if the compression is say 130 psi vs say 175-180, then the lower compression needs and will accept more timing advance. Both static and total mechanical advance. As long as the octane is good and no detonation or preignition exists.Start and Stage Your Studebakers
Most of the harmonic balancers in service were made 50+ years ago and the rubber bisquit between the balancer hub and weight deteriorates over the years and can allow the weight to move or slip causing the timing mark to move which makes it nearly impossible to set the timing correctly. There is something seriously wrong if you have to add 12 or 14 degrees of extra timing to get the engine to make good power. I recommend pulling the #1 plug and getting the piston as close to TDC on the compression stroke as you can and check the location of the timing marks. Bud
Originally posted by Jiles View PostWith all older vehicles, I adjust the timing by listening to the engine when under load.
I keep advancing the ignition until I hear SLIGHT pinging (pre ignition), then
back the timing off until ALL detonation is gone!
No, an R2 can melt itself before some old ears among us would detect that SLIGHT pinging.
Yes, agree, the timing marks are questionable, as 46 degrees is way to much initial plus centrifugal advance. Having said that, if vacuum advance is somehow being added in, the engine will cruise just fine at 46 degrees total if that 12 degrees of vacuum drops out when boost comes up.
Probably a dumb question but if the distributor were a tooth off, would that cause the issue?
jack vinesPackardV8
http://www.ifsja.org/forums/vb/showthread.php?t=34984
Originally posted by Bud View PostMost of the harmonic balancers in service were made 50+ years ago and the rubber bisquit between the balancer hub and weight deteriorates over the years and can allow the weight to move or slip causing the timing mark to move which makes it nearly impossible to set the timing correctly. There is something seriously wrong if you have to add 12 or 14 degrees of extra timing to get the engine to make good power. I recommend pulling the #1 plug and getting the piston as close to TDC on the compression stroke as you can and check the location of the timing marks. Bud
Originally posted by jeryst View PostProbably a dumb question but if the distributor were a tooth off, would that cause the issue?
That is interesting. What is the advantage of no timing advance mechanisms in the distributor? Do you have something somewhere else in the engine that will advance timing as needed?RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
60V-L6 - 60 Lark convertible
Originally posted by RadioRoy View PostThat is interesting. What is the advantage of no timing advance mechanisms in the distributor? Do you have something somewhere else in the engine that will advance timing as needed?
