dropped spindles
Originally posted by 64Avanti View PostInteresting. Did you calculate where the king pin axis intersects the tire patch?
Jack, before I posted information and photos of these lowered Kingpins, I spoke with Phil. They are still available, as to the price, Phil can answer that question.
John
Has anyone asked Phil Harris if the dropped spindles are still available and if so, how much?
Len, I am using QA1 rebuild-able, low friction ball joints. At the present state they are 13", center to center of the joint for an instant center of 120". QA1 has replaceable ball and studs up to 1.5" longer for a total of 16" if needed.
Guest repliedOriginally posted by Alan View Post67-68 rear steer. Moog K772, 68-89 Chrysler upper. Moog K727 60-66 Chrysler lowers. The lowers are installed upside down, or should I say opposite of the way Chev. put them in.
Guest repliedWhat year Camaro? Ditto ball joints.
Originally posted by JLB View PostBob........found the photos. Please send me a P.M. and I'll E-mail the photos to you sir.
Thanks
John
Putting the body back down on the frame in front will give you about 1 3/4" drop in front. You will need Studebaker style front fender openings so the tires do not contact fender lips. Lower yet you can use an AFCO coil with adjustable upper spring seats. That is what is in the Ron Hall Avanti. I was able to drop the spindle only 1/2". That is about as far as you can go. Ron's car is so low you cannot get a standard floor jack under it in front.
